I am adding a rechargeable coin cell to a custom carrier board, to be connected to the PMIC_BBAT pin:
https://www.digikey.com/en/products/detail/panasonic-bsg/ML-614S-FN/447506?s=N4IgTCBcDaILIBkC0A2AjAFgMoHoBiAciALoC%2BQA
In other forum posts, it is alluded to that a rechargeable battery can be used in the nano dev kit:
Is there any software setup required to use a rechargeable ML battery? The product design guide mentions that the PMIC_BBAT pin can charge a coin cell anywhere between 2.5V and 3.5V, but makes no mention of how to set the output voltage. Is any protection circuitry needed to use a rechargeable coin cell?
Thank you
