What is that current load of the Real Time clock circuit PMIC_BATT at following conditions:
1 Power ON
2 Power OFF
Second Question - If Non Rechargeable Lithium coin cell Battery is connected t the PMIC_BATT pin is there any safety concerns ?
1 Power ON
2 Power OFF
The typical current of RTC part is 2uA.
Only the following types are suggested:
• super capacitor
• standard capacitors (tantalum . . . etc.)
• rechargeable lithium manganese cells
HI
Thanks for the answer so it is 2uA for either ON or OFF conditions correct?
What happens if by mistake a Non Rechargeable Battery was inserted instead? Is there any damage to the Jetson Nano charging circuit? Are there any other risk issues that may happen?
Regards
Mati
It’s 2uA. Not suggest to use others than mentioned three.
Thanks for clarifying.
Other questions . Can you describe the Charging circuit operation?
Mati
Look for backup-battery node in device tree
it has CC and CV default value.
there are many threads on the values in devtalk
