Hi All,
I think I did my homework and I can’t find any resources for collecting CPU performance counters on TX1. I give a summary of my findings and please let me know if I’m missing something.
First of all, I went for Linux “perf”, the package managers can’t find in linux-tools and linux-tool-3.10.96. I got the source code and compiled it myself but it always returns “not-supported” for all counters. I checked linux kernel messages and I found:
“hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available”
which means profiling is enabled in my kernel.
I checked libpfm for L4T and the library is not available yet.
I tried to use Linux linux/perf_event.h but not sure about the reuslts. For example it returned very small numbers (around thousands) for CPU cycles while CPU freq is 1.7Ghz.
Nvidia has nvprof but it only collects results for CUDA programs. I also tried Tegra System profiler but it has two problems 1) it’s on the another machine 2) I couldn’t find all performance counters (if I’m not wrong I found cycles and some cache information) also I don’t like the GUI interface, I want something I can use in my scripts.
So in simple words does anyone used “perf” or something like it to collect the CPU performance counters? I’m pretty sure it should be something out there? NVIDIA has multiple tools for GPU but I need for CPU???
Thank you for all your help
Regards,
Reza
