how to do GPU performance monitor in Xavier (Solved)
cannot find nvidia-msi command, cannot find tegrastats command
Do you mean nvidia-smi?
nvidia-smi can only be used on the desktop environment.
For Jetson, please use tegrastats instead:
sudo ./tegrastats
Hi AastaLLL,
I enter “sudo ./tegrastats” command as you mentioned on Xavier. But I get the result as below. Do I need to install any other library to execute the command?
sudo: ./tegrastats: command not found
Thank you
Has this problem been solved?
I try the solution
and could use the command(sudo python3 tegrastats2.py --bin=/home/nvidia/tegrastats --output=./a.log --params “–interval 500”) to get the information as below.
But can not get visualization charts by the below command
python3 visualize.py --start=“2018-06-09 02:42:30” --end=“2018-06-09 02:43:15” --input=“/home/find/ddown/a.log” --output=./freq.xls
2019-06-12 08:16:24:
RAM 2210/24746MB (lfb 5352x4MB) CPU [0%,1%,3%,1%,2%,0%,0%,2%] EMC_FREQ @2133 GR3D_FREQ 3%@1185 APE 245 MTS fg 0% bg 0% AO@35.5C GPU@36C tj@49C AUX@36C CPU@36.5C Tdiode@36.25C
RAM 2210/24746MB (lfb 5352x4MB) CPU [0%,1%,2%,2%,0%,3%,1%,1%] EMC_FREQ @2133 GR3D_FREQ 0%@1185 APE 245 MTS fg 0% bg 0% AO@35C GPU@36.5C tj@49C AUX@36C CPU@36C Tdiode@36.25C
2019-06-12 08:16:25:
RAM 2210/24746MB (lfb 5352x4MB) CPU [2%,3%,2%,2%,1%,1%,2%,0%] EMC_FREQ @2133 GR3D_FREQ 0%@1185 APE 245 MTS fg 0% bg 1% AO@35.5C GPU@36C tj@49C AUX@36C CPU@36C Tdiode@36C
RAM 2210/24746MB (lfb 5352x4MB) CPU [0%,0%,1%,0%,0%,0%,2%,1%] EMC_FREQ @2133 GR3D_FREQ 0%@1185 APE 245 MTS fg 0% bg 0% AO@35.5C GPU@36C tj@49C AUX@36C CPU@36C Tdiode@36C
Run tegrastats on Jetson Xavier like you would a normal linux command:
$ tegrastats
Command line options include:
–interval [milliseconds]
–verbose
–stop [other instances of tegrastats]
–logfile
The “./” should not be part of that command (unless your working directory is the /usr/bin directory)
jwatte@jetson-nano:~$ which tegrastats
/usr/bin/tegrastats
jwatte@jetson-nano:~$ tegrastats
RAM 1486/3957MB (lfb 1x2MB) CPU [17%@102,11%@102,16%@102,10%@102] EMC_FREQ 0% GR3D_FREQ 5% PLL@31.5C CPU@37.5C PMIC@100C GPU@32C AO@38.5C thermal@34.75C POM_5V_IN 1594/1594 POM_5V_GPU 119/119 POM_5V_CPU 159/159
RAM 1486/3957MB (lfb 1x2MB) CPU [19%@102,11%@102,13%@102,9%@102] EMC_FREQ 0% GR3D_FREQ 39% PLL@31.5C CPU@37.5C PMIC@100C GPU@32C AO@38.5C thermal@34.75C POM_5V_IN 1634/1614 POM_5V_GPU 119/119 POM_5V_CPU 159/159
^C
(This happened to be on a nano, but it’s the same on my Xavier)
Isn’t there any tool that delivers the information from tegrastats in the form of graphs?
I can read any one line of output from tegrastats, yet, from a screen full of constantly changing characters I can not get any idea for my GPU and CPU usage. Clearly, a tool like “System Monitor” is infinitely more useful. Unfortunately, it reports only the CPU usage and nothing about the GPU.
It would be really helpful is there is one, else can someone please explain some of the information displayed here:
My tegrastats output
RAM 12681/15698MB (lfb 318x4MB) SWAP 22/7849MB (cached 0MB) CPU [84%@2265,23%@2265,58%@2265,1%@2265,18%@2265,59%@2265,33%@2265,28%@2265] EMC_FREQ 0% GR3D_FREQ 0% AO@44C GPU@47.5C Tboard@43C Tdiode@45.75C AUX@43.5C CPU@47.5C thermal@45.9C PMIC@100C GPU 0/0 CPU 6329/6329 SOC 2624/2624 CV 0/0 VDDRQ 308/308 SYS5V 2323/2323
What do these mean?
Hi tangenishikomba,
Please refer to https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%2520Linux%2520Driver%2520Package%2520Development%2520Guide%2FAppendixTegraStats.html%23
I found this site:
The visualization in the terminal is really great and works perfectly :)
Have fun.
