I would like to analysis my application performance with Nsight systems.
I profile my app but I confused at where should I check for GPU usage.
Hello @hkada,
Have you checked these tutorials below?
Nsight developer tool documentation is here.
https://docs.nvidia.com/nsight-systems/UserGuide/
Regards.
Thanks for your information.
I checked them. But I need to get gpu usage(ex. 60%) of my application.
You can check Nsight Compute for the GPU utilization.
https://developer.nvidia.com/tools-overview
Another alternative is to use tegrastats locally.
$ sudo tegrastats
I installed Nsight Compute.
But I have not use this one.
If I run my app, could I get profiling result of gpu utilities ?
You can get a report via profiling your application.
For example:
If the SM percentage is 0%, this indicates that the app doesn’t use GPU at all.
I ran my app with Nsight Compute.
However, the profiling image could not be reached.
Can you tell me the specific method?
Please try the following:
1. Setup root password as below comment:
2. Run ncu-ui → Connection → Connect …
- Press
+in the connection bar → Enter your device information (root account). - Enter executable/workspace information → Launch
