How can i check GPU utilization on nsight?
I’m trying to figure out where the bottleneck happens when I turn a number of processes around
So, How do I check GPU utilization on nsight systems?
I have information about SM active, warp, etc., but I don’t think there are any items that appear as Utilization.
So I’m trying to use Nsight compute and can I figure out GPU util through it?
GPU utilization can be found with tegrastats directly.
$ sudo tegrastats
But tegrastats don’t see gpu usage per process, do they?
I need information on how to use gpu in each process
Yes, the Nsight System is much better for the process-level info.
Do you get the “GPU Speed of Light” report when profiling the app?
You should be able to find the GPU utilization in the figure link below comment:
