Hi, I’m trying to run the SampleSSD project:
However, I get an error when trying to make the TensorRT project, which can be seen below.
[ 88%] Building CXX object samples/opensource/samplePlugin/CMakeFiles/sample_plugin.dir/samplePlugin.cpp.o
In file included from /home/magna/NVIDIA/sampleSSD/TensorRT/samples/opensource/samplePlugin/samplePlugin.cpp:29:0:
/usr/local/cuda-10.1/include/cuda_runtime_api.h:2484:88: error: use of enum ‘cudaStreamCaptureMode’ without previous declaration
extern host cudaError_t CUDARTAPI cudaStreamBeginCapture(cudaStream_t stream, enum cudaStreamCaptureMode mode);
/usr/local/cuda-10.1/include/cuda_runtime_api.h:2535:80: error: use of enum ‘cudaStreamCaptureMode’ without previous declaration
extern host cudaError_t CUDARTAPI cudaThreadExchangeStreamCaptureMode(enum cudaStreamCaptureMode *mode);
samples/opensource/samplePlugin/CMakeFiles/sample_plugin.dir/build.make:62: recipe for target ‘samples/opensource/samplePlugin/CMakeFiles/sample_plugin.dir/samplePlugin.cpp.o’ failed
make[2]: *** [samples/opensource/samplePlugin/CMakeFiles/sample_plugin.dir/samplePlugin.cpp.o] Error 1
CMakeFiles/Makefile2:2322: recipe for target ‘samples/opensource/samplePlugin/CMakeFiles/sample_plugin.dir/all’ failed
make[1]: *** [samples/opensource/samplePlugin/CMakeFiles/sample_plugin.dir/all] Error 2
Makefile:151: recipe for target ‘all’ failed
make: *** [all] Error 2
Could you please help me with this error?
Thank you
