Hi! I try to run tensorrt inference pipeline in c++
This is my code:
#include <iostream>
#include <fstream>
#include <opencv2/opencv.hpp>
#include <cuda_runtime_api.h>
#include <NvInfer.h>
#include <NvOnnxParser.h>
class Logger : public nvinfer1::ILogger {
public:
void log(Severity severity, const char* msg) noexcept override {
if ((severity == Severity::kWARNING) || (severity == Severity::kINTERNAL_ERROR)) {
std::cout << msg << std::endl;
} logger;
int main() {
std::string onnx_path = "./yolov5.onnx";
std::string engine_path = "trt.engine";
nvinfer1::ICudaEngine* engine;
nvonnxparser::IParser* parser;
nvinfer1::IBuilderConfig* config;
nvinfer1::INetworkDefinition* network;
nvinfer1::IBuilder* builder;
nvinfer1::IRuntime* infer;
// Building engine
builder = nvinfer1::createInferBuilder(logger);
builder->setMaxBatchSize(4);
network = builder->createNetworkV2(1U << static_cast<uint32_t>(nvinfer1::NetworkDefinitionCreationFlag::kEXPLICIT_BATCH));
parser = nvonnxparser::createParser(*network, logger);
if (!(parser->parseFromFile(onnx_path.c_str(), static_cast<uint32_t>(nvinfer1::ILogger::Severity::kWARNING)))) {
//we use parseFromFile instead of parse, since it has better error logging
for (int i = 0; i < parser->getNbErrors(); i++) {
std::cout << parser->getError(i)->desc() << std::endl;
throw std::runtime_error("Could not parse onnx model from file");
config = builder->createBuilderConfig();
config->setMaxWorkspaceSize(1<<25);
config->setFlag(nvinfer1::BuilderFlag::kFP16);
nvinfer1::IHostMemory* serialized_engine = builder->buildSerializedNetwork(*network, *config);
This is my cmakelists file:
cmake_minimum_required(VERSION 3.10)
project(Test)
set(CMAKE_CXX_STANDARD 17)
set(CUDA_TOOLKIT_ROOT_DIR /usr/local/cuda)
include_directories(/usr/include/opencv4/)
include_directories(/usr/lib/aarch64-linux-gnu)
find_package(OpenCV REQUIRED)
find_package(CUDA REQUIRED)
link_directories(/usr/lib/aarch64-linux-gnu/tegra)
add_executable(Test main.cpp)
target_include_directories(Test PUBLIC ${OpenCV_INCLUDE_DIRS} ${CUDA_INCLUDE_DIRS})
target_link_libraries(Test PUBLIC ${OpenCV_LIBS} ${CUDA_LIBRARIES} ${CMAKE_THREAD_LIBS_INIT} ${NVONNXPARSER_LIBRARY})
And when I run I have this errors:
CMakeFiles/Test.dir/main.cpp.o: In function `main':
main.cpp:(.text.startup+0x88): undefined reference to `createInferBuilder_INTERNAL'
collect2: error: ld returned 1 exit status
CMakeFiles/Test.dir/build.make:164: recipe for target 'Test' failed
make[3]: *** [BerlinTest] Error 1
CMakeFiles/Makefile2:67: recipe for target 'CMakeFiles/Test.dir/all' failed
make[2]: *** [CMakeFiles/Test.dir/all] Error 2
CMakeFiles/Makefile2:79: recipe for target 'CMakeFiles/Test.dir/rule' failed
make[1]: *** [CMakeFiles/Test.dir/rule] Error 2
Makefile:118: recipe for target 'Test' failed
make: *** [Test] Error 2
