I’m working on an SSD implementation in c++ using TensorRT. I’m working on
Tx2, Jetpack 3.3
Ubuntu 16.04
Cuda 9.0
TensorRT 4.0
The code is the following:
#include
#include “NvInferPlugin.h”
#include “NvInfer.h”
// Create global Logger object, gLogger
class Logger : public nvinfer1::ILogger
public:
void log(Severity severity, const char* msg) override
// suppress info messages
if (severity != Severity::kINFO)
std::cout << msg << std::endl;
Severity reportableSeverity{Severity::kWARNING};
static Logger gLogger;
int main(){
nvinfer1::IBuilder* builder;
builder = nvinfer1::createInferBuilder(gLogger);
The error is the following
[100%] Linking CXX executable testFile
CMakeFiles/testFile.dir/src/testFile.cpp.o: In function nvinfer1::(anonymous namespace)::createInferBuilder(nvinfer1::ILogger&)': testFile.cpp:(.text+0x14): [b]undefined reference to createInferBuilder_INTERNAL’[/b]
collect2: error: ld returned 1 exit status
CMakeFiles/testFile.dir/build.make:94: recipe for target ‘testFile’ failed
make[2]: *** [testFile] Error 1
CMakeFiles/Makefile2:67: recipe for target ‘CMakeFiles/testFile.dir/all’ failed
make[1]: *** [CMakeFiles/testFile.dir/all] Error 2
Makefile:83: recipe for target ‘all’ failed
make: *** [all] Error 2
I have not encountered a viable solution yet on the forum, did someone manage to fix this?
Kind regards and many thanks,
Umit
NVES
October 2, 2018, 6:17pm
2
createInferBuilder_INTERNAL is defined in libnvinfer.so. Double check your link instructions, make sure you are linking the nvinfer libraries.
Maybe drop your code snippet in one of the c++ examples in TRT samples folder and see if it builds. Reference the sample makefile for link examples.
NVES:
Hi @NVES , I’m running into the same issue.
CUDA 10.0, TensorRT 5, Ubuntu 16.04, GK107GLM [Quadro K1100M] laptop
Trying to write my own example for learning purposes to parse a caffe network, substitute custom plugin layers, etc. but I run into the following issue:
CMakeFiles/main.dir/trtNet.cpp.o: In function nvinfer1::(anonymous namespace)::createInferBuilder(nvinfer1::ILogger&)': trtNet.cpp:(.text+0x19): undefined reference to createInferBuilder_INTERNAL’
CMakeFiles/main.dir/trtNet.cpp.o: In function nvinfer1::(anonymous namespace)::createInferRuntime(nvinfer1::ILogger&)': trtNet.cpp:(.text+0x38): undefined reference to createInferRuntime_INTERNAL’
CMakeFiles/main.dir/trtNet.cpp.o: In function TRTNet::caffeToTRTModel(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&, unsigned int)': trtNet.cpp:(.text+0xad): undefined reference to nvcaffeparser1::createCaffeParser()’
trtNet.cpp:(.text+0x349): undefined reference to `nvcaffeparser1::shutdownProtobufLibrary()’
CMakeFiles/main.dir/build.make:148: recipe for target ‘main’ failed
make[2]: *** [main] Error 1
CMakeFiles/Makefile2:67: recipe for target ‘CMakeFiles/main.dir/all’ failed
make[1]: *** [CMakeFiles/main.dir/all] Error 2
Could you please direct me as to how I may link all the nvinfer libraries correctly to my development folder located elsewhere?
NVES:
I am also getting this error when I update my makefile based on the .config file in the samples:
/usr/include/cudnn.h:63:26: fatal error: driver_types.h: No such file or directory
compilation terminated.
Makefile:24: recipe for target ‘main.o’ failed
make: *** [main.o] Error 1
I have the cudnn samples running correctly.
NVES:
To solve the “fatal error: driver_types.h: No such file or directory”, you need to include in your ~/.bashrc like this
export C_INCLUDE_PATH=“/usr/local/cuda-10.0/include/:$C_INCLUDE_PATH”
export CPLUS_INCLUDE_PATH=“/usr/local/cuda-10.0/include/:$CPLUS_INCLUDE_PATH”
Add these lines at the bottom using gedit ~/.bashrc then source ~/.bashrc
Hi, you can do as follows:
add the libs:
/usr/lib/aarch64-linux-gnu/libnvparsers.so
where to add the .so file / lib ?
NVES
November 23, 2021, 5:38am
8
This looks like a Jetson issue. Please refer to the below samlples in case useful.
Hello AI World guide to deploying deep-learning inference networks and deep vision primitives with TensorRT and NVIDIA Jetson.
An easy to use PyTorch to TensorRT converter
For any further assistance, we recommend you to raise it to the respective platform from the below link
Discussions relating to the Jetson DevKits and other Embedded computing devices
