I installed PGI 14.10 on x86-64 CentOS, CUDA V5.5 and two nvidia geForce gtx 295. The pgCC compiler works fine, but when I include the file “cuda_profiler_api.h”:
#include <cuda_profiler_api.h>
in my C++ program, to use the functions:
cudaProfilerStart(); and cudaProfilerStop();
I get the following error from the pgCC compiler :
"acc_c1.cpp", line 15: catastrophic error: cannot open source file
"cuda_profiler_api.h"
I am compiling the program using the command line:
pgCC -fast -acc -ta=tesla:cc13 acc_c1.cpp -o executable
and I have also checked that $PATH and $LD_LIBRARY_PATH include /usr/local/cuda-5.5/bin and /usr/local/cuda-5.5/lib64. I found the file cuda_profiler_api.h at /usr/local/cuda-5.5/include and add this directory to the $PATH but still does not work.
