Hi everybody.
I need to compile code that both uses CUDA and Qt. My intention was to compile the CUDA code as a library (static or shared, I don’t really care) and link it to the main program that uses Qt. Now I’m trying to simply compile a piece of CUDA coda as a library and add it to a simple C file:
cudatest.h
[codebox]#include "cudatest.h"#define N (1<<20)
#define BLOCK_SIZE 64
global void function_gpu(float* A, float* C) {
unsigned int idx = threadIdx.x + BLOCK_SIZE*blockIdx.x;
if(idx<N-2) C[idx] = A[idx] + A[idx+1] + A[idx+2];
void function_cpu(float* A, float* C) {
int i;
for(i=0;i<N-2;i++) C[i]= A[i]+A[i+1]+A[i+2];
int cudamain(void) {
float *A, *C, *Ad, *Cd;
int i;
double error;
A = (float ) malloc(Nsizeof(float));
C = (float ) malloc(Nsizeof(float));
for(i=0;i<N;i++) A[i]=i;
cudaMalloc((void**)&Ad,N*sizeof(float));
cudaMalloc((void**)&Cd,N*sizeof(float));
cudaMemcpy(Ad,A,N*sizeof(float),cudaMemcpyHostToDevice);
cudaMemcpy(Cd,A,N*sizeof(float),cudaMemcpyHostToDevice);
dim3 dimBlock(BLOCK_SIZE);
dim3 dimGrid(N/BLOCK_SIZE);
function_gpu<<<dimGrid,dimBlock>>>(Ad,Cd);
cudaThreadSynchronize();
cudaMemcpy(C,Cd,N*sizeof(float),cudaMemcpyDeviceToHost);
cudaFree(Ad); cudaFree(Cd);
float Cc[N];
function_cpu(A,Cc);
error=0;
for(i=0;i<N-2;i++) error += abs(C[i]-Cc[i]);
printf(“Error=%f\n”,error);
if(error)
printf("!!! ERROR !!!\n");
return 0;
}[/codebox]
test.c
[codebox]prueba.o: In function `main':prueba.c:(.text+0x7): undefined reference to `cudamain’
cudaprueba.o: In function `cudamain()’:
tmpxft_00006955_00000000-10_cudaprueba.ii:(.text+0xb8): undefined reference to `cudaMalloc’
tmpxft_00006955_00000000-10_cudaprueba.ii:(.text+0xcb): undefined reference to `cudaMalloc’
tmpxft_00006955_00000000-10_cudaprueba.ii:(.text+0xed): undefined reference to `cudaMemcpy’
tmpxft_00006955_00000000-10_cudaprueba.ii:(.text+0x10f): undefined reference to `cudaMemcpy’
tmpxft_00006955_00000000-10_cudaprueba.ii:(.text+0x193): undefined reference to `cudaConfigureCall’
tmpxft_00006955_00000000-10_cudaprueba.ii:(.text+0x1ae): undefined reference to `cudaThreadSynchronize’
tmpxft_00006955_00000000-10_cudaprueba.ii:(.text+0x1d0): undefined reference to `cudaMemcpy’
tmpxft_00006955_00000000-10_cudaprueba.ii:(.text+0x1db): undefined reference to `cudaFree’
tmpxft_00006955_00000000-10_cudaprueba.ii:(.text+0x1e6): undefined reference to `cudaFree’
cudaprueba.o: In function `__cudaUnregisterBinaryUtil’:
tmpxft_00006955_00000000-10_cudaprueba.ii:(.text+0x28b): undefined reference to `__cudaUnregisterFatBinary’
cudaprueba.o: In function `__threadfence’:
tmpxft_00006955_00000000-10_cudaprueba.ii:(.text+0x4725): undefined reference to `__cudaSynchronizeThreads’
cudaprueba.o: In function `__threadfence_block’:
tmpxft_00006955_00000000-10_cudaprueba.ii:(.text+0x4751): undefined reference to `__cudaSynchronizeThreads’
cudaprueba.o: In function `__iAtomicAdd’:
tmpxft_00006955_00000000-10_cudaprueba.ii:(.text+0x4dc1): undefined reference to `__cudaMutexOperation’
tmpxft_00006955_00000000-10_cudaprueba.ii:(.text+0x4de2): undefined reference to `__cudaMutexOperation’
cudaprueba.o: In function `__uAtomicAdd’:
tmpxft_00006955_00000000-10_cudaprueba.ii:(.text+0x4df9): undefined reference to `__cudaMutexOperation’
tmpxft_00006955_00000000-10_cudaprueba.ii:(.text+0x4e1a): undefined reference to `__cudaMutexOperation’
cudaprueba.o: In function `__iAtomicExch’:
tmpxft_00006955_00000000-10_cudaprueba.ii:(.text+0x4e31): undefined reference to `__cudaMutexOperation’
cudaprueba.o:tmpxft_00006955_00000000-10_cudaprueba.ii:(.text+0x4e4d): more undefined references to `__cudaMutexOperation’ follow
cudaprueba.o: In function `__itexfetchi’:
tmpxft_00006955_00000000-10_cudaprueba.ii:(.text+0x75bc): undefined reference to `__cudaTextureFetch’
cudaprueba.o: In function `__utexfetchi’:
tmpxft_00006955_00000000-10_cudaprueba.ii:(.text+0x7606): undefined reference to `__cudaTextureFetch’
cudaprueba.o: In function `__ftexfetchi’:
tmpxft_00006955_00000000-10_cudaprueba.ii:(.text+0x7650): undefined reference to `__cudaTextureFetch’
cudaprueba.o: In function `__itexfetch’:
tmpxft_00006955_00000000-10_cudaprueba.ii:(.text+0x769a): undefined reference to `__cudaTextureFetch’
cudaprueba.o: In function `__utexfetch’:
tmpxft_00006955_00000000-10_cudaprueba.ii:(.text+0x76e4): undefined reference to `__cudaTextureFetch’
cudaprueba.o:tmpxft_00006955_00000000-10_cudaprueba.ii:(.text+0x772e): more undefined references to `__cudaTextureFetch’ follow
cudaprueba.o: In function `_device_stub__Z7funcionPfS’:
tmpxft_00006955_00000000-10_cudaprueba.ii:(.text+0xd343): undefined reference to `cudaSetupArgument’
tmpxft_00006955_00000000-10_cudaprueba.ii:(.text+0xd369): undefined reference to `cudaSetupArgument’
cudaprueba.o: In function `__sti____cudaRegisterAll_45_tmpxft_00006955_00000000_4_c
udaprueba_cpp1_ii_bd1fe0ee’:
tmpxft_00006955_00000000-10_cudaprueba.ii:(.text+0xd3bd): undefined reference to `__cudaRegisterFatBinary’
tmpxft_00006955_00000000-10_cudaprueba.ii:(.text+0xd424): undefined reference to `__cudaRegisterFunction’
cudaprueba.o: In function `cudaError cudaLaunch(char*)’:
tmpxft_00006955_00000000-10_cudaprueba.ii:(.text.Z10cudaLaunchIcE9cudaErrorPT[cudaE
rror cudaLaunch(char*)]+0xd): undefined reference to `cudaLaunch’
cudaprueba.o:(.eh_frame+0x12): undefined reference to `__gxx_personality_v0’
collect2: ld returned 1 exit status[/codebox]
It seems that, on one side, it can’t link the .cu and .c files and, on the other, can’t link the .cu with the CUDA library (however, I can compile .cu files on its own).
Any help?
