1> Compiling CUDA source file bandwidthTest.cu…
1>
1> C:\ProgramData\NVIDIA Corporation\CUDA Samples\v8.0\1_Utilities\bandwidthTest>“C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v8.0\bin\nvcc.exe” -gencode=arch=compute_20,code="sm_20,compute_20" -gencode=arch=compute_30,code="sm_30,compute_30" -gencode=arch=compute_35,code="sm_35,compute_35" -gencode=arch=compute_37,code="sm_37,compute_37" -gencode=arch=compute_50,code="sm_50,compute_50" -gencode=arch=compute_52,code="sm_52,compute_52" -gencode=arch=compute_60,code="sm_60,compute_60" --use-local-env --cl-version 2015 -ccbin “C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64” -I./ -I…/…/common/inc -I./ -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v8.0/include" -I…/…/common/inc -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v8.0\include" -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -Xcompiler “/wd 4819” -g -DWIN32 -DWIN32 -D_MBCS -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /FS /Zi /RTC1 /MTd " -o x64/Debug/bandwidthTest.cu.obj “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v8.0\1_Utilities\bandwidthTest\bandwidthTest.cu”
1>CUDACOMPILE : nvcc warning : The ‘compute_20’, ‘sm_20’, and ‘sm_21’ architectures are deprecated, and may be removed in a future release (Use -Wno-deprecated-gpu-targets to suppress warning).
1> bandwidthTest.cu
1>C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\BuildCustomizations\CUDA 8.0.targets(689,9): error MSB3721: 命令““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v8.0\bin\nvcc.exe” -gencode=arch=compute_20,code="sm_20,compute_20" -gencode=arch=compute_30,code="sm_30,compute_30" -gencode=arch=compute_35,code="sm_35,compute_35" -gencode=arch=compute_37,code="sm_37,compute_37" -gencode=arch=compute_50,code="sm_50,compute_50" -gencode=arch=compute_52,code="sm_52,compute_52" -gencode=arch=compute_60,code="sm_60,compute_60" --use-local-env --cl-version 2015 -ccbin “C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64” -I./ -I…/…/common/inc -I./ -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v8.0/include” -I…/…/common/inc -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v8.0\include" -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -Xcompiler “/wd 4819” -g -DWIN32 -DWIN32 -D_MBCS -D_MBCS -Xcompiler "/EHsc /W3 /nologo /Od /FS /Zi /RTC1 /MTd " -o x64/Debug/bandwidthTest.cu.obj “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v8.0\1_Utilities\bandwidthTest\bandwidthTest.cu””
In a previous thread, txbob said:
thank you for your help
cicc.exe and the fold nvvm is missing in my installation
I mannually copy them into the setup fold
It works now
