I have problem to compile the SDK sample. I get this error :
make[1]: Entering directory `/home/user/NVIDIA_GPU_Computing_SDK/C/common'
make[1]: Leaving directory `/home/user/NVIDIA_GPU_Computing_SDK/C/common'
make[1]: Entering directory `/home/user/NVIDIA_GPU_Computing_SDK/shared'
make[1]: Leaving directory `/home/user/NVIDIA_GPU_Computing_SDK/shared'
make -C src/BlackScholes/
make[1]: Entering directory `/home/user/NVIDIA_GPU_Computing_SDK/C/src/BlackScholes'
make[1]: Leaving directory `/home/user/NVIDIA_GPU_Computing_SDK/C/src/BlackScholes'
make -C src/oceanFFT/
make[1]: Entering directory `/home/user/NVIDIA_GPU_Computing_SDK/C/src/oceanFFT'
make[1]: Leaving directory `/home/user/NVIDIA_GPU_Computing_SDK/C/src/oceanFFT'
make -C src/binomialOptions/
make[1]: Entering directory `/home/user/NVIDIA_GPU_Computing_SDK/C/src/binomialOptions'
make[1]: Leaving directory `/home/user/NVIDIA_GPU_Computing_SDK/C/src/binomialOptions'
make -C src/template/
make[1]: Entering directory `/home/user/NVIDIA_GPU_Computing_SDK/C/src/template'
make[1]: Leaving directory `/home/user/NVIDIA_GPU_Computing_SDK/C/src/template'
make -C src/MonteCarloMultiGPU/
make[1]: Entering directory `/home/user/NVIDIA_GPU_Computing_SDK/C/src/MonteCarloMultiGPU'
make[1]: Leaving directory `/home/user/NVIDIA_GPU_Computing_SDK/C/src/MonteCarloMultiGPU'
make -C src/simpleZeroCopy/
make[1]: Entering directory `/home/user/NVIDIA_GPU_Computing_SDK/C/src/simpleZeroCopy'
make[1]: Leaving directory `/home/user/NVIDIA_GPU_Computing_SDK/C/src/simpleZeroCopy'
make -C src/FDTD3d/
make[1]: Entering directory `/home/user/NVIDIA_GPU_Computing_SDK/C/src/FDTD3d'
make[1]: Leaving directory `/home/user/NVIDIA_GPU_Computing_SDK/C/src/FDTD3d'
make -C src/simplePitchLinearTexture/
make[1]: Entering directory `/home/user/NVIDIA_GPU_Computing_SDK/C/src/simplePitchLinearTexture'
make[1]: Leaving directory `/home/user/NVIDIA_GPU_Computing_SDK/C/src/simplePitchLinearTexture'
make -C src/alignedTypes/
make[1]: Entering directory `/home/user/NVIDIA_GPU_Computing_SDK/C/src/alignedTypes'
make[1]: Leaving directory `/home/user/NVIDIA_GPU_Computing_SDK/C/src/alignedTypes'
make -C src/recursiveGaussian/
make[1]: Entering directory `/home/user/NVIDIA_GPU_Computing_SDK/C/src/recursiveGaussian'
make[1]: Leaving directory `/home/user/NVIDIA_GPU_Computing_SDK/C/src/recursiveGaussian'
make -C src/simpleTexture/
make[1]: Entering directory `/home/user/NVIDIA_GPU_Computing_SDK/C/src/simpleTexture'
make[1]: Leaving directory `/home/user/NVIDIA_GPU_Computing_SDK/C/src/simpleTexture'
make -C src/simpleTextureDrv/
make[1]: Entering directory `/home/user/NVIDIA_GPU_Computing_SDK/C/src/simpleTextureDrv'
obj/x86_64/release/simpleTextureDrv.cpp.o: In function `initCUDA(int, char**, CUfunc_st**)':
simpleTextureDrv.cpp:(.text+0x644): undefined reference to `cuModuleLoadDataEx'
collect2: ld returned 1 exit status
make[1]: *** [../../bin/linux/release/simpleTextureDrv] Error 1
make[1]: Leaving directory `/home/user/NVIDIA_GPU_Computing_SDK/C/src/simpleTextureDrv'
make: *** [src/simpleTextureDrv/Makefile.ph_build] Error 2
Do someone has an idea of the problem ?
cheers
make -C src/FDTD3d/
cheers
I have exactly the same problem on Ubuntu 10.10 64 machine! Anyone out there…???
make -C src/FDTD3d/
cheers
I do not know about Ubuntu (using Debian) but will try to help.
I can think about two possible causes of those problems
You miss some packages.
Install all available NVIDIA packages. Here is list from my system:
libcuda1
libcuda1-dev
libgl1-nvidia-alternatives
libgl1-nvidia-dev
libgl1-nvidia-glx
libglx-nvidia-alternatives
libnvidia-compiler
nvidia-glx
nvidia-glx-dev
nvidia-kernel-dkms
nvidia-kernel-source
nvidia-libopencl1
nvidia-libopencl1-dev
nvidia-opencl-common
nvidia-opencl-icd
nvidia-smi
nvidia-vdpau-driver
nvidia-xconfig
The mos important is libcuda1 and libcuda1-dev, libnvidia-compiler (used to compile PTX to CUBIN).
Conflict between driver version and CUDA toolkit version.
Drivers 195.x (available in Debian testing and unstable and Ubuntu) do not cooperate well with CUDA toolkit 3.1. To have working CUDA 3.1 you need drivers 256.53 (available in Debian experimental).
Please reply whether any of those help to solve your problems/
libcuda1
libcuda1-dev
libgl1-nvidia-dev
libgl1-nvidia-glx
libnvidia-compiler
nvidia-glx
nvidia-glx-dev
nvidia-kernel-dkms
nvidia-libopencl1
nvidia-opencl-icd
nvidia-smi
nvidia-vdpau-driver
nvidia-xconfig
