I ran into the following problem when using the NVIDIA Fortran compiler (e.g. nvfortran 26.1):
module my_module
implicit none
abstract interface
pure real function fun_interface()
end function fun_interface
end interface
contains
real function my_wrapper(fun)
implicit none
procedure(fun_interface) :: fun
my_wrapper = wrapper_wrapper()
! This always works on GCC and on NVHPC:
! my_wrapper = fun()
contains
real function wrapper_wrapper()
wrapper_wrapper = fun()
end function wrapper_wrapper
end
end module my_module
program example
use my_module
implicit none
! This works on GCC and on NVHPC
! real, parameter :: target_value = .5
! This works on GCC, not on NVHPC
real :: target_value
target_value = 0.5
print*, "Via wrapper (should equal .5): ", my_wrapper(my_fun)
print*, "Direct call (should equal .5): ", my_fun()
contains
pure real function my_fun()
my_fun = target_value
end function my_fun
end program example
nvfortran gives as output:
❯ nvfortran test.f90 -o test_nvidia
❯ ./test_nvidia
Via wrapper (should equal .5): -2168.705
Direct call (should equal .5): 0.5000000
This problem does not occur using GNU, Intel or NAG Fortran compilers.
