When compiling the following code the arguments number 7 and furthers are passed per value to the function instead per reference:
PROGRAM ERR
IMPLICIT NONE
C
INTEGER4 IND
INTEGER8 GEO_CALC_ADR, STATUS
C
INTEGER4, PARAMETER :: MT = 2
INTEGER4
& FIRST_COL_OUT(MT),
& FIRST_LIN_OUT(MT),
& NUM_COLS_OUT(MT),
& NUM_LINS_OUT(MT),
& FIRST_COL_IN(MT),
& FIRST_LIN_IN(MT),
& NUM_COLS_IN(MT),
& NUM_LINS_IN(MT),
& FIRST_COL_DEM(MT),
& FIRST_LIN_DEM(MT),
& NUM_COLS_DEM(MT),
& NUM_LINS_DEM(MT)
C
PRINT*, ‘starting’
FIRST_COL_OUT = 0
FIRST_LIN_OUT = 0
NUM_COLS_OUT = 0
NUM_LINS_OUT = 0
FIRST_COL_IN = 0
FIRST_LIN_IN = 0
NUM_COLS_IN = 0
NUM_LINS_IN = 0
FIRST_COL_DEM = 0
FIRST_LIN_DEM = 0
NUM_COLS_DEM = 0
NUM_LINS_DEM = 0
C
IND = 1
PRINT*,‘Calling’
STATUS = GEO_CALC_ADR (FIRST_COL_OUT(IND),FIRST_LIN_OUT(IND),
& NUM_COLS_OUT(IND),NUM_LINS_OUT(IND),
& FIRST_COL_DEM(IND),FIRST_LIN_DEM(IND),
& NUM_COLS_DEM(IND),NUM_LINS_DEM(IND),
& FIRST_COL_IN(IND),FIRST_LIN_IN(IND),
& NUM_COLS_IN(IND),NUM_LINS_IN(IND))
PRINT*,‘End’
END
C
RECURSIVE INTEGER8 FUNCTION GEO_CALC_ADR (FIRST_COL_OUT,FIRST_LIN_OUT,
& NCOLS_OUT,NLINS_OUT,
& FIRST_COL_DEM,FIRST_LIN_DEM,
& NCOLS_DEM,NLINS_DEM,
& FIRST_COL_IN,FIRST_LIN_IN,
& NCOLS_IN,NLINS_IN)
IMPLICIT NONE
INTEGER4
& FIRST_COL_OUT,
& FIRST_LIN_OUT,
& NCOLS_OUT,
& NLINS_OUT,
& FIRST_COL_DEM,
& FIRST_LIN_DEM,
& NCOLS_DEM,
& NLINS_DEM,
& FIRST_COL_IN,
& FIRST_LIN_IN,
& NCOLS_IN,
& NLINS_IN
C
PRINT*,‘In Function’
FIRST_COL_OUT = 0
FIRST_LIN_OUT = 0
NCOLS_OUT = 0
NLINS_OUT = 0
FIRST_COL_DEM = 0
FIRST_LIN_DEM = 0
NCOLS_DEM = 0
NLINS_DEM = 0
FIRST_COL_IN = 0
FIRST_LIN_IN = 0
NCOLS_IN = 0
NLINS_IN = 0
C
GEO_CALC_ADR = -1
RETURN
END
