Nvfortran error: PASS argument is incompatible with parent's PASS argument
Hi there,
The attached code fails to compile with the following:
[sfilippo@euler TNV]$ nvfortran --version
nvfortran 24.3-0 64-bit target on x86-64 Linux -tp alderlake
NVIDIA Compilers and Tools
Copyright (c) 2024, NVIDIA CORPORATION & AFFILIATES.  All rights reserved.
[sfilippo@euler TNV]$ nvfortran -c test.f90
NVFORTRAN-S-0155-PASS argument is incompatible with parent's PASS argument in type bound procedure x_zzz_get_nz_row (test.f90: 70)
NVFORTRAN-S-0155-Dummy argument names must be the same as those in parent's interface for type bound procedure x_zzz_get_nz_row (test.f90: 70)
NVFORTRAN-S-0155-Interface is not compatible with parent's interface for type bound procedure x_zzz_get_nz_row (test.f90: 70)
NVFORTRAN/x86-64 Linux 24.3-0: compilation completed with severe errors
The code (reduced and extracted from a much more complex source) compiles fine with many other compilers, including GNU, FLANG, Intel and others.
Is this a code issue or an nvfortran problem?
Salvatore
module base_mod
  use iso_fortran_env
  integer, parameter  :: ipk_  = int32
  integer, parameter  :: lpk_  = int64
  type  :: base
  contains
    procedure, pass(a) :: get_nz_row  => base_get_nz_row
  end type base
  interface
    module function base_get_nz_row(idx,a) result(res)
      integer(ipk_), intent(in)                    :: idx
      class(base), intent(in) :: a
      integer(ipk_) :: res
    end function base_get_nz_row
  end interface
end module base_mod
module x_base_mod
  use base_mod
  type, extends(base) :: x_base
  end type x_base
  type, extends(x_base) :: x_yyy
  contains
    procedure, pass(a) :: get_nz_row   => x_yyy_get_nz_row
  end type x_yyy
  interface
    function  x_yyy_get_nz_row(idx,a) result(res)
      import
      class(x_yyy), intent(in) :: a
    end function x_yyy_get_nz_row
  end interface
end module x_base_mod
module x_zzz_mod
  use x_base_mod
  type, extends(x_base) :: x_zzz
  contains
    procedure, pass(a) :: get_nz_row  => x_zzz_get_nz_row
  end type x_zzz
  private :: x_zzz_get_nz_row
contains
  function  x_zzz_get_nz_row(idx,a) result(res)
    implicit none
    class(x_zzz), intent(in) :: a
    res = 0
  end function x_zzz_get_nz_row
end module x_zzz_mod
Thanks for the report Salvatore. I filed it as TPR #35450 and sent it to engineering for investigation.
-Mat
Hi Salvatore,
FYI, TPR #35450 was fixed in our 24.9 release.
% nvfortran -c -V24.7 pass.F90
NVFORTRAN-S-0155-PASS argument is incompatible with parent's PASS argument in type bound procedure x_zzz_get_nz_row (pass.F90: 70)
NVFORTRAN-S-0155-Dummy argument names must be the same as those in parent's interface for type bound procedure x_zzz_get_nz_row (pass.F90: 70)
NVFORTRAN-S-0155-Interface is not compatible with parent's interface for type bound procedure x_zzz_get_nz_row (pass.F90: 70)
NVFORTRAN/x86-64 Linux 24.7-0: compilation completed with severe errors
% nvfortran -c -V24.9 pass.F90
-Mat
