Frontend bug: Illegal number or type of arguments
Originally this bug can be triggered in the following example using OpenMPI:
module provider_m
  use iso_c_binding
  interface
    subroutine callback(userdata)
      import
      type(c_ptr), intent(in) :: userdata(:)
    end
  end interface
contains
  subroutine go(prec)
    procedure(callback) prec
  end
end
module consumer_m
  use mpi_f08 ! <-- remove this to make the error disappear
  use provider_m
contains
  subroutine process
    call go(op)
  end
  subroutine op(userdata)
  end
end
This was actually quite hard to reduce, because it doesn’t trigger reliably. The smallest dependency-free example I could make is 164 lines and has five modules. Any little variation to this example, e.g. deleting a seemingly unused variable in one of the modules makes the bug disappear.
Live example on Compiler Explorer
minimal.f90
module mpi_types
  type MPI_Status
  end type
  type MPI_Comm
  end type
  type MPI_Datatype
    integer :: MPI_VAL
  end type
  type MPI_Errhandler
    integer :: MPI_VAL
  end type
  type MPI_VAL
  end type
  type MPI_Group
    integer :: MPI_VAL
  end type
  type MPI_Info
    integer :: MPI_VAL
  end type
  type MPI_Message
    integer :: MPI_VAL
  end type
  type MPI_Op
    integer :: MPI_VAL
  end type
  type MPI_Request
  end type
  type MPI_Session
  end type
  type MPI_Win
  end type
end
module mpi_f08_types
  use mpi_types
  logical :: MPI_COMM_WORLD(1)
  type(MPI_Message) :: MPI_MESSAGE_NO_PROC(1)
  type(MPI_Info) :: MPI_INFO_ENV(1)
  type(MPI_Op) :: MPI_MAX(1)
  type(MPI_Op) :: MPI_MIN(1)
  type(MPI_Op) :: MPI_SUM(1)
  type(MPI_Op) :: MPI_PROD(1)
  type(MPI_Op) :: MPI_LAND(1)
  type(MPI_Op) :: MPI_BAND(1)
  type(MPI_Op) :: MPI_LOR(1)
  type(MPI_Op) :: MPI_BOR(1)
  type(MPI_Op) :: MPI_LXOR(1)
  type(MPI_Op) :: MPI_BXOR(1)
  type(MPI_Op) :: MPI_MAXLOC(1)
  type(MPI_Op) :: MPI_COMM_NULL(1)
  type(MPI_Datatype) :: MPI_DATATYPE_NULL(1)
  type(MPI_Errhandler) :: MPI_ERRHANDLER_NULL(1)
  type(MPI_Group) :: MPI_GROUP_NULL(1)
  type(MPI_Info) :: MPI_INFO_NULL(1)
  type(MPI_Message) :: MPI_MESSAGE_NULL(1)
  type(MPI_Op) :: MPI_SESSION_NULL(1)
  type(MPI_Datatype) :: MPI_AINT(1)
  type(MPI_Datatype) :: MPI_BYTE(1)
  type(MPI_Datatype) :: MPI_PACKED(1)
  type(MPI_Datatype) :: MPI_UB(1)
  type(MPI_Datatype) :: MPI_LB(1)
  type(MPI_Datatype) :: MPI_CHAR(1)
  type(MPI_Datatype) :: MPI_SIGNED_CHAR(1)
  type(MPI_Datatype) :: MPI_UNSIGNED_CHAR(1)
  type(MPI_Datatype) :: MPI_WCHAR(1)
  type(MPI_Datatype) :: MPI_CHARACTER(1)
  type(MPI_Datatype) :: MPI_LOGICAL(1)
  type(MPI_Datatype) :: MPI_INT(1)
  type(MPI_Datatype) :: MPI_INT16_T(1)
  type(MPI_Datatype) :: MPI_INT32_T(1)
  type(MPI_Datatype) :: MPI_INT64_T(1)
  type(MPI_Datatype) :: MPI_INT8_T(1)
  type(MPI_Datatype) :: MPI_UINT16_T(1)
  type(MPI_Datatype) :: MPI_UINT32_T(1)
  type(MPI_Datatype) :: MPI_UINT64_T(1)
  type(MPI_Datatype) :: MPI_UINT8_T(1)
  type(MPI_Datatype) :: MPI_SHORT(1)
  type(MPI_Datatype) :: MPI_UNSIGNED_SHORT(1)
  type(MPI_Datatype) :: MPI_UNSIGNED(1)
  type(MPI_Datatype) :: MPI_LONG(1)
  type(MPI_Datatype) :: MPI_UNSIGNED_LONG(1)
  type(MPI_Datatype) :: MPI_LONG_LONG(1)
  type(MPI_Datatype) :: MPI_UNSIGNED_LONG_LONG(1)
  type(MPI_Datatype) :: MPI_LONG_LONG_INT(1)
  type(MPI_Datatype) :: MPI_INTEGER(1)
  type(MPI_Datatype) :: MPI_INTEGER1(1)
  type(MPI_Datatype) :: MPI_INTEGER2(1)
  type(MPI_Datatype) :: MPI_INTEGER4(1)
  type(MPI_Datatype) :: MPI_INTEGER8(1)
  type(MPI_Datatype) :: MPI_INTEGER16(1)
  type(MPI_Datatype) :: MPI_FLOAT(1)
  type(MPI_Datatype) :: MPI_DOUBLE(1)
  type(MPI_Datatype) :: MPI_LONG_DOUBLE(1)
  type(MPI_Datatype) :: MPI_REAL(1)
  type(MPI_Datatype) :: MPI_REAL4(1)
  type(MPI_Datatype) :: MPI_REAL8(1)
  type(MPI_Datatype) :: MPI_REAL16(1)
  type(MPI_Datatype) :: MPI_DOUBLE_PRECISION(1)
  type(MPI_Datatype) :: MPI_C_COMPLEX(1)
  type(MPI_Datatype) :: MPI_C_FLOAT_COMPLEX(1)
  type(MPI_Datatype) :: MPI_C_DOUBLE_COMPLEX(1)
  type(MPI_Datatype) :: MPI_C_LONG_DOUBLE_COMPLEX(1)
  type(MPI_Datatype) :: MPI_CXX_COMPLEX(1)
  type(MPI_Datatype) :: MPI_CXX_FLOAT_COMPLEX(1)
  type(MPI_Datatype) :: MPI_CXX_DOUBLE_COMPLEX(1)
  type(MPI_Datatype) :: MPI_CXX_LONG_DOUBLE_COMPLEX(1)
  type(MPI_Datatype) :: MPI_COMPLEX(1)
  type(MPI_Datatype) :: MPI_COMPLEX8(1)
  type(MPI_Datatype) :: MPI_COMPLEX16(1)
  type(MPI_Datatype) :: MPI_COMPLEX32(1)
  type(MPI_Datatype) :: MPI_DOUBLE_COMPLEX(1)
  type(MPI_Datatype) :: MPI_FLOAT_INT(1)
  type(MPI_Datatype) :: MPI_DOUBLE_INT(1)
  type(MPI_Datatype) :: MPI_2REAL(1)
  type(MPI_Datatype) :: MPI_2DOUBLE_PRECISION(1)
  type(MPI_Datatype) :: MPI_2INT(1)
  type(MPI_Datatype) :: MPI_SHORT_INT(1)
  type(MPI_Datatype) :: MPI_LONG_INT(1)
  type(MPI_Datatype) :: MPI_LONG_DOUBLE_INT(1)
  type(MPI_Datatype) :: MPI_2INTEGER(1)
  type(MPI_Datatype) :: MPI_2COMPLEX(1)
  type(MPI_Datatype) :: MPI_2DOUBLE_COMPLEX(1)
  type(MPI_Datatype) :: MPI_REAL2(1)
  type(MPI_Datatype) :: MPI_LOGICAL1(1)
  type(MPI_Datatype) :: MPI_LOGICAL2(1)
  type(MPI_Datatype) :: MPI_LOGICAL4(1)
  type(MPI_Datatype) :: MPI_LOGICAL8(1)
  type(MPI_Datatype) :: MPI_C_BOOL(1)
  type(MPI_Datatype) :: MPI_CXX_BOOL(1)
  type(MPI_Datatype) :: MPI_COUNT(1)
  type(MPI_Datatype) :: MPI_OFFSET(1)
  type(MPI_Datatype), parameter :: MPI_COMPLEX4 = MPI_Datatype(0)
end
module pmpi_f08_interfaces
  interface
    subroutine PMPI_Neighbor_alltoallw_init_f08
      use mpi_f08_types
      use ISO_C_BINDING
    end
  end interface
end
module provider_m
  use iso_c_binding
  interface
      import
    end
  end interface
contains
  subroutine go(prec)
  end
end
module consumer_m
  use pmpi_f08_interfaces
  use provider_m
contains
  subroutine process
    call go(op)
  end
  end
end
Since this is so hard to trigger it makes me think that this might have something to do with the internal state of the parser.
Here I would also be really interested in a workaround for my part of the code, because I can’t easily edit OpenMPI.
Hi herni.menke,
I filed a report, TPR #38322, and sent it to engineering for investigation.
I found that if I reverse the order of the modules, i.e. put “use provider_m” before “use mpi_f90”, then it works.
If that’s not a viable work around for you, I also tried it with our new Fortran compiler that were working on with the LLVM Community, and it worked without issue. While the new nvfortran is still a bit away, you can download the open source version from: llvm-project/flang at main · llvm/llvm-project · GitHub, if you want to give it try.
-Mat
