nvm i got this problem fixed. I had to change the 32 bit compatibility.
I am running Ubuntu 8.1 64bit and CUDA 2. I having trouble compiling the SDK from Nvidia. I already have the driver and toolbox installed.
here’s the error I’m getting when I compile using make:
[codebox]make[1]: Entering directory `/root/NVIDIA_CUDA_SDK/common’
a - obj/release/bank_checker.cpp.o
a - obj/release/cmd_arg_reader.cpp.o
a - obj/release/cutil.cpp.o
a - obj/release/stopwatch.cpp.o
a - obj/release/stopwatch_linux.cpp.o
a - obj/release/multithreading.cpp.o
make[1]: Leaving directory `/root/NVIDIA_CUDA_SDK/common’
a - obj/release/paramgl.cpp.o
a - obj/release/param.cpp.o
a - obj/release/rendercheck_gl.cpp.o
make -C projects/simpleTextureDrv/
make[1]: Entering directory `/root/NVIDIA_CUDA_SDK/projects/simpleTextureDrv’
In file included from /usr/include/features.h:354,
from /usr/local/cuda/bin/../include/host_config.h:53,
from /usr/local/cuda/bin/../include/cuda_runtime.h:45,
from <command-line>:0:
/usr/include/gnu/stubs.h:7:27: error: gnu/stubs-32.h: No such file or directory
make[1]: *** [data/simpleTexture_kernel.cubin] Error 255
make[1]: Leaving directory `/root/NVIDIA_CUDA_SDK/projects/simpleTextureDrv’
make: *** [projects/simpleTextureDrv/Makefile.ph_build] Error 2[/codebox]
Thanks you in advance.
