When running compute-sanitizer ./main, I get the error:
========= COMPUTE-SANITIZER
========= Error: Target application terminated before first instrumented API call
========= Error: couldn't find exit code.
Note that I had to move compute-sanitizer from /usr/bin/compute-sanitizer to /usr/lib/nvidia-cuda-toolkit/compute-sanitizer/compute-sanitizer because otherwise it would crash with the error message Unable to find injection library libsanitizer-collection.so.
I also found the similar issue Compute Sanitizer always report "Target application terminated before first instrumented API call" but I might have a different problem because TreeLauncherSubreaper and TreeLauncherTargetLdPreloadHelper look sufficiently executable:
$ ls -l /usr/bin | grep TreeLauncher
-rwxr-xr-x 1 root root 162648 Nov 19 2021 TreeLauncherSubreaper
-rwxr-xr-x 1 root root 14336 Nov 19 2021 TreeLauncherTargetLdPreloadHelper
Here is the output of strace compute-sanitizer ./main in case it is useful for debugging this issue.
execve("/usr/bin/compute-sanitizer", ["compute-sanitizer", "./main"], 0x7ffe6addd5b8 /* 61 vars */) = 0
brk(NULL) = 0x16e6000
arch_prctl(0x3001 /* ARCH_??? */, 0x7ffc390a8b00) = -1 EINVAL (Invalid argument)
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x78297bf38000
access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=108179, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 108179, PROT_READ, MAP_PRIVATE, 3, 0) = 0x78297bf1d000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libpthread.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0\0\0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=21448, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 16424, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x78297bf18000
mmap(0x78297bf19000, 4096, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x78297bf19000
mmap(0x78297bf1a000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x78297bf1a000
mmap(0x78297bf1b000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x78297bf1b000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/librt.so.1", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=14664, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 16440, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x78297bf13000
mmap(0x78297bf14000, 4096, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x78297bf14000
mmap(0x78297bf15000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x78297bf15000
mmap(0x78297bf16000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x78297bf16000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libdl.so.2", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=14432, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 16424, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x78297bf0e000
mmap(0x78297bf0f000, 4096, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x78297bf0f000
mmap(0x78297bf10000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x78297bf10000
mmap(0x78297bf11000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x78297bf11000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libutil.so.1", O_RDONLY|O_CLOEXEC) = 3
mmap(NULL, 16424, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x78297bf09000
mmap(0x78297bf0a000, 4096, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x78297bf0a000
mmap(0x78297bf0b000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x78297bf0b000
mmap(0x78297bf0c000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x78297bf0c000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libm.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0\0\0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=940560, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 942344, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x78297be22000
mmap(0x78297be30000, 507904, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe000) = 0x78297be30000
mmap(0x78297beac000, 372736, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x8a000) = 0x78297beac000
mmap(0x78297bf07000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe4000) = 0x78297bf07000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=125488, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 127720, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x78297be02000
mmap(0x78297be05000, 94208, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3000) = 0x78297be05000
mmap(0x78297be1c000, 16384, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1a000) = 0x78297be1c000
mmap(0x78297be20000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1d000) = 0x78297be20000
close(3) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x78297be00000
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libc.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0P\237\2\0\0\0\0\0"..., 832) = 832
pread64(3, "\6\0\0\0\4\0\0\0@\0\0\0\0\0\0\0@\0\0\0\0\0\0\0@\0\0\0\0\0\0\0"..., 784, 64) = 784
pread64(3, "\4\0\0\0 \0\0\0\5\0\0\0GNU\0\2\0\0\300\4\0\0\0\3\0\0\0\0\0\0\0"..., 48, 848) = 48
pread64(3, "\4\0\0\0\24\0\0\0\3\0\0\0GNU\0I\17\357\204\3$\f\221\2039x\324\224\323\236S"..., 68, 896) = 68
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=2220400, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 2264656, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x78297ba00000
mprotect(0x78297ba28000, 2023424, PROT_NONE) = 0
mmap(0x78297ba28000, 1658880, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x28000) = 0x78297ba28000
mmap(0x78297bbbd000, 360448, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1bd000) = 0x78297bbbd000
mmap(0x78297bc16000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x215000) = 0x78297bc16000
mmap(0x78297bc1c000, 52816, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x78297bc1c000
close(3) = 0
mmap(NULL, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x78297bdfd000
arch_prctl(ARCH_SET_FS, 0x78297bdfd780) = 0
set_tid_address(0x78297bdfda50) = 67846
set_robust_list(0x78297bdfda60, 24) = 0
rseq(0x78297bdfe120, 0x20, 0, 0x53053053) = 0
mprotect(0x78297bc16000, 16384, PROT_READ) = 0
mprotect(0x78297be20000, 4096, PROT_READ) = 0
mprotect(0x78297bf07000, 4096, PROT_READ) = 0
mprotect(0x78297bf0c000, 4096, PROT_READ) = 0
mprotect(0x78297bf11000, 4096, PROT_READ) = 0
mprotect(0x78297bf16000, 4096, PROT_READ) = 0
mprotect(0x78297bf1b000, 4096, PROT_READ) = 0
mprotect(0xaae000, 225280, PROT_READ) = 0
mprotect(0x78297bf72000, 8192, PROT_READ) = 0
prlimit64(0, RLIMIT_STACK, NULL, {rlim_cur=8192*1024, rlim_max=RLIM64_INFINITY}) = 0
munmap(0x78297bf1d000, 108179) = 0
getrandom("\x9c\xe3\xbd\x54\x76\xaa\xc4\x23", 8, GRND_NONBLOCK) = 8
brk(0x1707000) = 0x1707000
futex(0xaf8d9c, FUTEX_WAKE_PRIVATE, 2147483647) = 0
futex(0xaf8da8, FUTEX_WAKE_PRIVATE, 2147483647) = 0
brk(0x1738000) = 0x1738000
newfstatat(1, "", {st_mode=S_IFCHR|0600, st_rdev=makedev(0x88, 0x4), ...}, AT_EMPTY_PATH) = 0
write(1, "========= COMPUTE-SANITIZER\n", 28) = 28
stat("./main", {st_mode=S_IFREG|0775, st_size=807664, ...}) = 0
getcwd("/home/username/cuda", 260) = 22
readlink("/proc/self/exe", "/usr/lib/nvidia-cuda-toolkit/com"..., 260) = 64
stat("/usr/lib/nvidia-cuda-toolkit/compute-sanitizer/libsanitizer-collection.so", {st_mode=S_IFREG|0644, st_size=7778136, ...}) = 0
access("/home/username/cuda/./main", F_OK) = 0
access("/home/username/cuda/./main", R_OK|X_OK) = 0
epoll_create1(EPOLL_CLOEXEC) = 3
mkdir("/tmp/NVIDIA-treetracker-xLZxuw", 0700) = 0
access("/home/username/cuda", F_OK) = 0
stat("/home/username/cuda", {st_mode=S_IFDIR|0775, st_size=4096, ...}) = 0
gettid() = 67846
getpid() = 67846
openat(AT_FDCWD, "/proc/67846/status", O_RDONLY) = 4
newfstatat(4, "", {st_mode=S_IFREG|0444, st_size=0, ...}, AT_EMPTY_PATH) = 0
read(4, "Name:\tcompute-sanitiz\nUmask:\t000"..., 1024) = 1024
close(4) = 0
readlink("/proc/self/exe", "/usr/lib/nvidia-cuda-toolkit/com"..., 4096) = 64
openat(AT_FDCWD, "/usr/lib/nvidia-cuda-toolkit/compute-sanitizer//nvlog.config", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/username/nvlog.config", O_RDONLY) = -1 ENOENT (No such file or directory)
mknodat(AT_FDCWD, "/tmp/NVIDIA-treetracker-xLZxuw/pipe-0-ownerReadingStream", S_IFIFO|0666) = 0
mknodat(AT_FDCWD, "/tmp/NVIDIA-treetracker-xLZxuw/pipe-0-ownerWritingStream", S_IFIFO|0666) = 0
openat(AT_FDCWD, "/tmp/NVIDIA-treetracker-xLZxuw/pipe-0-ownerReadingStream", O_RDONLY|O_NONBLOCK) = 4
openat(AT_FDCWD, "/tmp/NVIDIA-treetracker-xLZxuw/pipe-0-ownerWritingStream", O_RDWR|O_NONBLOCK) = 5
epoll_ctl(3, EPOLL_CTL_ADD, 4, {events=EPOLLIN|EPOLLET, data={u32=24117184, u64=24117184}}) = 0
clone(child_stack=NULL, flags=CLONE_CHILD_CLEARTID|CLONE_CHILD_SETTID|SIGCHLD, child_tidptr=0x78297bdfda50) = 67847
rt_sigaction(SIGRT_1, {sa_handler=0x78297ba91870, sa_mask=[], sa_flags=SA_RESTORER|SA_ONSTACK|SA_RESTART|SA_SIGINFO, sa_restorer=0x78297ba42520}, NULL, 8) = 0
rt_sigprocmask(SIG_UNBLOCK, [RTMIN RT_1], NULL, 8) = 0
mmap(NULL, 8392704, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x78297b000000
mprotect(0x78297b001000, 8388608, PROT_READ|PROT_WRITE) = 0
rt_sigprocmask(SIG_BLOCK, ~[], [], 8) = 0
clone3({flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, child_tid=0x78297b800910, parent_tid=0x78297b800910, exit_signal=0, stack=0x78297b000000, stack_size=0x7ffec0, tls=0x78297b800640} => {parent_tid=[67848]}, 88) = 67848
rt_sigprocmask(SIG_SETMASK, [], NULL, 8) = 0
mmap(NULL, 8392704, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x78297a600000
mprotect(0x78297a601000, 8388608, PROT_READ|PROT_WRITE) = 0
clone3({flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, child_tid=0x78297ae00910, parent_tid=0x78297ae00910, exit_signal=0, stack=0x78297a600000, stack_size=0x7ffec0, tls=0x78297ae00640} => {parent_tid=[67849]}, 88) = 67849
mmap(NULL, 8392704, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x782979c00000
mprotect(0x782979c01000, 8388608, PROT_READ|PROT_WRITE) = 0
clone3({flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, child_tid=0x78297a400910, parent_tid=0x78297a400910, exit_signal=0, stack=0x782979c00000, stack_size=0x7ffec0, tls=0x78297a400640} => {parent_tid=[67850]}, 88) = 67850
mmap(NULL, 8392704, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x782979200000
mprotect(0x782979201000, 8388608, PROT_READ|PROT_WRITE) = 0
clone3({flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, child_tid=0x782979a00910, parent_tid=0x782979a00910, exit_signal=0, stack=0x782979200000, stack_size=0x7ffec0, tls=0x782979a00640} => {parent_tid=[67851]}, 88) = 67851
--- SIGCHLD {si_signo=SIGCHLD, si_code=CLD_EXITED, si_pid=67847, si_uid=1000, si_status=255, si_utime=0, si_stime=0} ---
mmap(NULL, 8392704, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x782978800000
mprotect(0x782978801000, 8388608, PROT_READ|PROT_WRITE) = 0
clone3({flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, child_tid=0x782979000910, parent_tid=0x782979000910, exit_signal=0, stack=0x782978800000, stack_size=0x7ffec0, tls=0x782979000640} => {parent_tid=[67852]}, 88) = 67852
eventfd2(0, EFD_CLOEXEC|EFD_NONBLOCK) = 6
epoll_create1(EPOLL_CLOEXEC) = 7
timerfd_create(CLOCK_MONOTONIC, TFD_CLOEXEC) = 8
epoll_ctl(7, EPOLL_CTL_ADD, 6, {events=EPOLLIN|EPOLLERR|EPOLLET, data={u32=24116376, u64=24116376}}) = 0
write(6, "\1\0\0\0\0\0\0\0", 8) = 8
epoll_ctl(7, EPOLL_CTL_ADD, 8, {events=EPOLLIN|EPOLLERR, data={u32=24116388, u64=24116388}}) = 0
futex(0x1702a48, FUTEX_WAKE_PRIVATE, 1) = 1
clock_gettime(CLOCK_REALTIME, {tv_sec=1727984965, tv_nsec=622728336}) = 0
write(1, "========= Error: Target applicat"..., 82) = 82
futex(0x7ffc390a87c4, FUTEX_WAIT_PRIVATE, 8, NULL) = -1 EAGAIN (Resource temporarily unavailable)
futex(0x7ffc390a87c4, FUTEX_WAIT_PRIVATE, 12, NULL) = 0
epoll_ctl(7, EPOLL_CTL_MOD, 6, {events=EPOLLIN|EPOLLERR|EPOLLET, data={u32=24116376, u64=24116376}}) = 0
futex(0x17029e8, FUTEX_WAKE_PRIVATE, 1) = 1
close(7) = 0
close(8) = 0
close(6) = 0
futex(0x1703e88, FUTEX_WAKE_PRIVATE, 2147483647) = 1
futex(0x16ff4b8, FUTEX_WAIT_BITSET_PRIVATE|FUTEX_CLOCK_REALTIME, 0, NULL, FUTEX_BITSET_MATCH_ANY) = -1 EAGAIN (Resource temporarily unavailable)
futex(0x16ff468, FUTEX_WAKE_PRIVATE, 1) = 0
munmap(0x78297a600000, 8392704) = 0
close(4) = 0
close(5) = 0
unlink("/tmp/NVIDIA-treetracker-xLZxuw/pipe-0-ownerReadingStream") = 0
unlink("/tmp/NVIDIA-treetracker-xLZxuw/pipe-0-ownerWritingStream") = 0
close(3) = 0
lstat("/tmp/NVIDIA-treetracker-xLZxuw", {st_mode=S_IFDIR|0700, st_size=40, ...}) = 0
openat(AT_FDCWD, "/tmp/NVIDIA-treetracker-xLZxuw", O_RDONLY|O_NONBLOCK|O_CLOEXEC|O_DIRECTORY) = 3
newfstatat(3, "", {st_mode=S_IFDIR|0700, st_size=40, ...}, AT_EMPTY_PATH) = 0
getdents64(3, 0x17180d0 /* 2 entries */, 32768) = 48
getdents64(3, 0x17180d0 /* 0 entries */, 32768) = 0
close(3) = 0
rmdir("/tmp/NVIDIA-treetracker-xLZxuw") = 0
exit_group(-1) = ?
+++ exited with 255 +++
Here is the CUDA code I used, but it happens with every program.
#include <cuda.h>
#include <stdio.h>
__global__ void illegal_read(int *ptr){
int value = ptr[threadIdx.x];
printf("%d: %d\n", threadIdx.x, value);
int main(){
int *array;
int n = 16;
cudaMallocManaged(&array, n * sizeof(int));
for(int i = 0; i < n; i++){
array[i] = i;
illegal_read<<<1, 32>>>(array);
cudaDeviceSynchronize();
cudaFree(array);
return 0;
$ compute-sanitizer --version
NVIDIA (R) Compute Sanitizer
Copyright (c) 2020-2021 NVIDIA Corporation
Version 2021.3.1
$ nvidia-smi
Thu Oct 3 21:26:47 2024
| NVIDIA-SMI 550.107.02 Driver Version: 550.107.02 CUDA Version: 12.4 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 3060 ... Off | 00000000:01:00.0 On | N/A |
| N/A 42C P8 11W / 80W | 252MiB / 6144MiB | 47% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1331 G /usr/lib/xorg/Xorg 149MiB |
$ nvcc --version
Copyright (c) 2005-2021 NVIDIA Corporation
Built on Thu_Nov_18_09:45:30_PST_2021
Cuda compilation tools, release 11.5, V11.5.119
Build cuda_11.5.r11.5/compiler.30672275_0
