Compute Sanitizer Error
I get the following error when trying to launch compute-sanitizer.
========= COMPUTE-SANITIZER
GPU Device 0: “Orin” - “Ampere” with compute capability 8.7
========= Internal Sanitizer Error: Failed to initialize mobile debugger interface. Please check that /dev NVIDIA nodes have the correct permissions
========= Internal Sanitizer Error: Device not supported. Please refer to the “Supported Devices” section of the sanitizer documentation
I added $USER to the debug group but it still gives me the same errors.
Jetson’s profiler requires root authority. Please run it with sudo.
For example:
$ sudo ./compute-sanitizer ../samples/0_Simple/vectorAdd/vectorAdd
[Vector addition of 50000 elements]
Copy input data from the host memory to the CUDA device
CUDA kernel launch with 196 blocks of 256 threads
Copy output data from the CUDA device to the host memory
Test PASSED
Done
========= ERROR SUMMARY: 0 errors
This works thank you.
