hi all,
I am a beginner using Jetson and I am learning about Memory Encryption. I saw BCT flags (enable_nsdram_encryption and enable_blanket_nsdram_carveout) are set by default to enable DRAM encryption on the T234 Jetson boards
May I ask where is the BCT flags configuration file? I searched the forum and mentioned the MB1 configuration file, but I couldn’t find it. Can you tell me which package to download? I am currently using L4T 35.4.1
It would be even better if the compilation process could be provided.
you should install the Jetpack release image to your local host machine.
and, you shall see the mb1-bct file with following configuraitons,
for example, $OUT/Linux_for_Tegra/bootloader/tegra234-mb1-bct-misc-common.dtsi
