Hi gang -
I’m looking for suggestions on enabling a Remote FX GPU on my Dell.
Current setup:
Dell VRTX
M620 Poweredge
Quadro M4000 (alternate, Quadro P4000)
Win2012R2, utilizing Hyper-V
** Note - the M4000 is a new install; The device pass-through is recognized by the OS, but the Win driver has been an issue.
Attempt 1:
Installed driver & RTX DesktopManager (v472.98 & 202.21). The server will start but the driver errors. If I disable then re-enable the device, it will then start.
However 1) DXDIAG will not recognize the hardware; 2) RTX Desktop Manager reports it cannot run because it requires:
Windows 10 and above
NVIDIA display driver
Nvidia RTX / Quadro GPU
** Note - this results from installing 472.98-quadro-rtx-winserv-2012r2-64bit-international-whql.exe
** Note - Hyper-V does not recognize an available GPU to be assigned.
– This is telling me that, while the device is powered-up (verified via CMC & the cooling fan spinning up), the driver is not allowing the GPU to mount successfully.
Attempt 2:
Install clean via 453.10-quadro-winserv-2012r2-64bit-international-whql.exe
This driver results in system instability, ultimately requiring it be removed.
Attempt 3+:
Attempted alternate drivers, but so far the best (nonfunctional) result was with the 472.x (and have been removed).
Alternate path(s):
-Install WinServ2016
-Verify the device is not the problem by installing into another system, or, an alternate OS (currently WIP)
