Hi @nhashimoto,
Thank you for your reply and support.
How to observe actual SM utilization per workload under MIG on GH200 - Accelerated Computing / Aerial Forum - NVIDIA Developer Forums
We are planning to run CUBB E2E testing soon and are currently preparing the required hardware and cables.
Our planned connections are:
- CX-8 400G QSFP ↔ CX-7 200G
- CX-7 200G ↔ CX-7 200G
For CX-8 ↔ CX-7, should we use a 400G-to-2×200G breakout cable, or configure the CX-8 port to 200GbE and use a direct 200G Ethernet cable?
For CX-7 ↔ CX-7, is a 200G QSFP56 DAC sufficient?
If possible, could you also share the recommended cable P/N or the cable configuration used in NVIDIA’s CUBB E2E setup?
Thank you.
BR,
August
Hi @august.lai ,
You can confirm what speed your NIC support with the ethtool <interface> command. If both ports support 200G, you can connect directly.
Yes, it’s sufficient for up to 20 cells.
Here are the qualified cable lists for CX-7 and CX-8.
Thank you,
Nori
Hi @nhashimoto,
Thanks for the clarification on the cable requirements. We proceeded with the CUBB E2E setup and have one additional question regarding the GH200 power configuration for the TestMAC side.
After a clean reboot, before launching the cuBB container or any TestMAC workload, we observed:
GH200 Module Power Limit:
Current / Requested / Default / Max = 1000 W
GPU Power Limit:
Current / Requested = 700 W
Default / Max = 900 W
BMC DCMI Chassis Power Limit:
State = Active
Power Limit = 500 W
Correction Time = 1000 ms
cuBB_system_checks.py does not report any issue related to these power limits, and the other host configuration checks are passing.
Could you please confirm:
What GPU power limit and chassis/platform power limit are used on NVIDIA’s GH200 reference CUBB E2E setup?
Is GPU Current/Requested Power Limit = 700 W expected, or should it be set to 900 W for performance benchmarking?
Is an active 500 W DCMI chassis power cap expected, or could it limit 10-cell / 20-cell / TxR scaling performance?
Does cuBB_system_checks.py intentionally not validate these power-limit settings?
We would like to align our GH200 TestMAC platform with NVIDIA’s reference configuration before starting the performance benchmark.
BR,
August
Hi August,
Aerial doesn’t need a large power drain compared to AI applications.
For the Aerial workload, 700 W is good enough to achieve 20 cells. I don’t think you can see a large difference between 700 and 900 W in performance metrics, but there is no reason to limit the power.
It would be good to set it to 900 W.
Thank you,
Nori
Hi Nori,
Thank you very much for your quick response. Your feedback is very important to us as we are trying to align our setup with NVIDIA’s recommended Aerial 26-1 benchmark configuration.
We will set the GPU power limit to 900 W as suggested.
One more question regarding the platform power setting:
Our TestMAC server is QCT’s S7G platform (QuantaGrid S74G-2U) based on NVIDIA GH200, rather than NVIDIA’s Supermicro GH200 reference system.
On this S7G platform, the BMC DCMI reports an active 500 W chassis power limit with a 1000 ms correction time:
Current Limit State : Power Limit Active
Power Limit : 500 Watts
Correction time : 1000 milliseconds
Is this chassis power cap something that should be adjusted for the Aerial 20-cell performance benchmark?
Or is the chassis power limit considered platform/BMC-specific, in which case should I confirm the recommended setting with our internal QCT BMC/platform team?
Thank you.
BR,
August
Hi August,
I checked the SMC server, but it doesn’t have such a power limitation from the BMC level.
From the Aerial perspective, power consumption will not exceed 500 W during a 1,000-millisecond period. I guess it is not a problem, but all our tests for GH200 have been done with the SMC servers. I wouldn’t say it is 100% safe.
If it really limits the power drain to the GPU, can you ask Quanta if this value can be changed?
Thank you.
Hi Nori,
Thank you for your previous response regarding the platform power limit. We have checked this internally on the QCT S7G platform, and the power-setting issue has now been resolved.
I have one more question regarding L1 processing latency measurement in Aerial 26-1.
We found that the following metric is exposed from the Aerial metrics endpoint:
aerial_cuphycp_slot_processing_duration_us
However, during our TestMAC F08 / 59c workloads, the histogram _count, _sum, and _bucket values remain at 0, so we cannot obtain P50/P95/P99 L1 processing latency from Prometheus/Grafana.
We also checked the 26-1 source and found that the processing-time metric update calls in the active PDSCH/PUSCH/PUCCH callback paths appear to be disabled/commented out.
What is NVIDIA’s recommended method in Aerial 26-1 to measure cuPHY/L1 processing latency in µs?
Is aerial_cuphycp_slot_processing_duration_us expected to work with the TestMAC 59c workload?
If this metric is intentionally disabled in 26-1, is there another officially supported metric or tool for measuring PDSCH/PUSCH processing latency?
We would like to use the NVIDIA-recommended method so that the latency result remains comparable with the official Aerial benchmark methodology.
Thank you.
BR,
August
Hi August,
Can you create a new topic for the inquiry?
Your inquiry would be helpful for other developers/users, but they cannot find this with the current topic title.
Thank you.
