Conflict between GCC 11.4 and libboost_1.74 in Jetpack 6.0 GA
I am trying to compile some code on Jetson AGX Orin DevKit both directly and via docker image (nvcr.io/nvidia/deepstream:7.0-samples-multiarch). However, I met an error with libboost_1.74 as below:
/usr/include/boost/geometry/geometries/point_xy.hpp: In member function ‘void boost::geometry::model::d2::point_xy<CoordinateType, CoordinateSystem>::x(const CoordinateType&)’:
/usr/include/boost/geometry/geometries/point_xy.hpp:74:27: error: type/value mismatch at argument 1 in template parameter list for ‘template<class _Key, class _Compare, class _Alloc> class std::set’
   74 |     { this->template set<0>(v); }
/usr/include/boost/geometry/geometries/point_xy.hpp:74:27: note:   expected a type, got ‘0’
/usr/include/boost/geometry/geometries/point_xy.hpp:74:27: error: template argument 2 is invalid
/usr/include/boost/geometry/geometries/point_xy.hpp:74:27: error: template argument 3 is invalid
/usr/include/boost/geometry/geometries/point_xy.hpp: In member function ‘void boost::geometry::model::d2::point_xy<CoordinateType, CoordinateSystem>::y(const CoordinateType&)’:
/usr/include/boost/geometry/geometries/point_xy.hpp:78:27: error: type/value mismatch at argument 1 in template parameter list for ‘template<class _Key, class _Compare, class _Alloc> class std::set’
   78 |     { this->template set<1>(v); }
/usr/include/boost/geometry/geometries/point_xy.hpp:78:27: note:   expected a type, got ‘1’
/usr/include/boost/geometry/geometries/point_xy.hpp:78:27: error: template argument 2 is invalid
/usr/include/boost/geometry/geometries/point_xy.hpp:78:27: error: template argument 3 is invalid
In file included from /usr/include/boost/math/tools/cxx03_warn.hpp:9,
                 from /usr/include/boost/math/constants/constants.hpp:11,
                 from /usr/include/boost/geometry/util/math.hpp:29,
                 from /usr/include/boost/geometry/core/radian_access.hpp:33,
                 from /usr/include/boost/geometry/geometry.hpp:51,
                 from /usr/include/boost/geometry.hpp:17,
As my investigation, it is an issue of GCC 11.4 . I am testing by upgrading GCC/G++ to version of 12.x or later (It is still fail with GCC 12.3 and not supported GCC 13.2). Can anyone give some other suggestions for fixing this problem?
GCC 12 is available in Ubuntu 22.04 as pre-built binaries.
I tested with GCC 12.3 but there was still same error and then updated to GCC 13.2 but GNU and nvcc are not supported yet.
Then you should ask support from boost to solve compilation error.
I don’t think this is about Jetson.
