Connect Retinanet DLA model with NMS
Description
I’m following https://github.com/NVIDIA/Deep-Learning-Accelerator-SW/tree/main/scripts/prepare_models in attempt to use DLA for object detection, in particular the “retinanet_resnext50.py”
After the running python3 retinanet_resnext50.py and getting the .onnx file, I observed that the NMS layers are no where to be found, so it is not a proper object detection model…
Can you help point me to some resources or provide a cookbook on how to make the conversion end-to-end starting from an onnx file → tensorRT engine that used DLA and also includes retinanet outputs (bboxes, labels, etc.)
Environment
Orin AGX
The below 2 links should be helpful for you -
