I have a dual port ConnectX-3. On port 1, I have an 850nm Finisar multi mode SFP. On port 2, I’d like to use a fiberstore 1370nm single mode SFP. Does the card support this kind of configuration? Or would I need to use two cards?
Hi Mike,
Following the link to the Release Notes of latest Firmware version 2.42.5000 for the ConnectX-3 cards----> https://www.mellanox.com/pdf/firmware/ConnectX3-FW-2_42_5000-release_notes.pdf
Section 1.2 “Supported Cables and Modules” lists the Tested/Supported cables/modules. If you are using from this list, it should work. If not, we cannot guarantee if it will work or not.
If you face issues using supported matrix, as you have a valid support contract with us, you may open a support ticket with us.
Thanks,
Namrata.
