My fiber ISP uses 2.5G SFP modules and I was wondering if there are any Mellanox ConnectX cards that support syncing at this speed over fiber?
Hi Mattias,
Thank you for posting your question on the Mellanox Community.
Based on the information provided, unfortunately we do not support the cable in the current line of adapters. From a previous post, we noticed that you are using a ConnectX-2, also this adapter is not supported anymore as it is EOL and EOS.
For supported cables, please refer to the firmware RN of the ConnectX-5 EN → http://www.mellanox.com/pdf/firmware/ConnectX5-FW-16_23_1020-release_notes.pdf http://www.mellanox.com/pdf/firmware/ConnectX5-FW-16_23_1020-release_notes.pdf
Thanks and regards,
~Mellanox Technical Support
