supporting 1000base with a connectx-3
Hello all,
I am still learning the ropes with these cards so hopefully I include the right details.
the card in this server is:
# mstflint -d 42:00.0 q
Image type: FS2
FW Version: 2.32.5100
FW Release Date: 3.9.2014
Product Version: 02.32.51.00
Rom Info: type=PXE version=3.4.306 devid=4099 proto=ETH
Device ID: 4099
Description: Node Port1 Port2 Sys image
GUIDs: ffffffffffffffff ffffffffffffffff ffffffffffffffff ffffffffffffffff
MACs: f452141fd030 f452141fd031
VSD:
PSID: MT_1080120023
I can see the following with ethtool:
# ethtool p4p1
Settings for p4p1:
Supported ports: [ FIBRE ]
Supported link modes: 1000baseKX/Full
10000baseKR/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: No
Advertised link modes: 1000baseKX/Full
10000baseKR/Full
Advertised pause frame use: Symmetric
Advertised auto-negotiation: No
Speed: Unknown!
Duplex: Unknown! (255)
Port: FIBRE
PHYAD: 0
Transceiver: internal
Auto-negotiation: off
Supports Wake-on: d
Wake-on: d
Current message level: 0x00000014 (20)
link ifdown
Link detected: no
The network engineer on the Cisco side says he can see the SFP on that side is happy but no link. I can’t see a link either and now the question is what have I done wrong in relation to getting this card working. The drivers for the card appear to be installed correctly etc.
And yet speed and duplex are unknown. The SFPs on the switch side can only support 1000.
Thanks for your time all.
I’m using an LC\LC fibre cable. The SFP in the card is an MLX.MFM1T02A-SR (part number I have on invoice) and the SFP on the Cisco side is a Cisco module - the part number of which I do not have to hand.
OFED self test shows the cards as not connected.
# hca_self_test.ofed
---- Performing Adapter Device Self Test ----
Number of CAs Detected … 1
PCI Device Check … PASS
Kernel Arch … x86_64
Host Driver Version … MLNX_OFED_LINUX-2.3-2.0.0 (OFED-2.3-2.0.0): 2.6.32-504.el6.x86_64
Host Driver RPM Check … PASS
Firmware on CA #0 NIC … v2.32.5100
Firmware Check on CA #0 (NIC) … PASS
Host Driver Initialization … PASS
Number of CA Ports Active … 0
Port State of Port #1 on CA #0 (NIC)… DOWN (Ethernet)
Port State of Port #2 on CA #0 (NIC)… DOWN (Ethernet)
Error Counter Check on CA #0 (NIC)… NA (Eth ports)
Kernel Syslog Check … PASS
Node GUID on CA #0 (NIC) …
------------------ DONE ---------------------
I’m just trying to figure our where in the chain things are not as they should be…
mmmm
I think you are going to say I need an MC3208011-SX SFP to get this to work.
What cable / SFP adapter are you using ? do you have OFED installed ?
