Firmware upgrade for ConnectX-2
in three computers I have three dual port 10 Gb NICs ConnectX-2. I would like to upgrade their firmwares. I followed instruction how to identify correct adapter on: Firmware Support and Downloads - Identifying Adapter Cards Firmware Support and Downloads - Identifying Adapter Cards
I got these results:
C:\Program Files\Mellanox\WinMFT>mst status
MST devices:
mt26448_pci_cr0
mt26448_pciconf0
C:\Program Files\Mellanox\WinMFT>flint -d /dev/mst/mt26448_pci_cr0 query
Image type: FS2
FW Version: 2.7.8200
Rom Info: type=PXE version=1.5.6 devid=26448 proto=ETH
Device ID: 26448
Description: Port1 Port2
VSD:
PSID: IBM0DB0000010
C:\Program Files\Mellanox\WinMFT>flint -d /dev/mst/mt26448_pciconf0 query
Image type: FS2
Device ID: 26448
VSD:
PSID: IBM0DB0000010
The problem is that PSID is not in the format “MT_”.
I checked a list of firmwares on Firmware for ConnectX®-2 EN Firmware for ConnectX®-2 EN and I am not sure what is the correct.
Can anyone give me advice please?
I suppose I have MNPH29C-XTR because I found photo of a card on eBay (looks same as my card) and the card is described as MNPH29C-XTR.
And the second question please:
When I type “mst status” then I got two devices. Should I run update for both of them?
flint -d -I burn
flint -d -I burn
Thank you.
Rick Penic
Thank you very much for your fast reply. I updated the firmware without any problem.
I found that other two cards are HP branded. I put into Google: HP_0CD0210010 and HP_0CD0210010 and I found that it is a card 516937-B21 (same card, different revision) so I downloaded firmware here.
So at this moment I have 2.9.1530 on HP cards and 2.9.1000 on IBM card. And it is working so I am happy. Again thank you very much…
Btw.: Explanation why all cards are different: It is testing environment (not production)
Hi Rick,
According to the PSID it’s an IBM OEM card, so you can download the fw to it from:
Lenovo Intelligent Cluster Lenovo Intelligent Cluster
regarding the 2nd question, no need to upgrade both entries, they actually represent the same device only a different access method to it, the mt26448_pci_cr0 device is a bit faster so you can use it
