Is this a supported 56Gbe configuration?
I’m using a SN2100 switch and everything seems to work fine with ConnectX-5 cards. I was just trying to add another older server using ConnectX-3 cards, which I expected to work at 56Gbe, but I get no link. I’ve installed all of the latest drivers and firmware, and I’m using MCP1600 cables. The cards are 354A-FCBT. Both ports are configured for etrhernet:
/sbin/connectx_port_config -s
Port configuration for PCI device: 0000:06:00.0 is:
eth
eth# ethtool p4p1
Settings for p4p1:
Supported ports: [ FIBRE ]
Supported link modes: 1000baseKX/Full
10000baseKX4/Full
10000baseKR/Full
40000baseCR4/Full
40000baseSR4/Full
56000baseCR4/Full
56000baseSR4/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 1000baseKX/Full
10000baseKX4/Full
10000baseKR/Full
40000baseCR4/Full
40000baseSR4/Full
Advertised pause frame use: Symmetric
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Speed: Unknown!
Duplex: Unknown! (255)
Port: FIBRE
PHYAD: 0
Transceiver: internal
Auto-negotiation: off
Supports Wake-on: d
Wake-on: d
Current message level: 0x00000014 (20)
link ifdown
Link detected: no
ethtool p4p2
Settings for p4p2:
10000baseKX4/Full
10000baseKR/Full
40000baseCR4/Full
40000baseSR4/Full
56000baseCR4/Full
56000baseSR4/Full
10000baseKX4/Full
10000baseKR/Full
40000baseCR4/Full
40000baseSR4/Full
Speed: Unknown!
Port: FIBRE
PHYAD: 0
Supports Wake-on: d
Wake-on: d
link ifdown
Link detected: no
hca_self_test.ofed
---- Performing Adapter Device Self Test ----
Number of CAs Detected … 1
PCI Device Check … PASS
Kernel Arch … x86_64
Host Driver Version … MLNX_OFED_LINUX-4.6-1.0.1.1 (OFED-4.6-1.0.1): 3.10.0-957.el7.x86_64
Host Driver RPM Check … PASS
Firmware on CA #0 VPI … v2.42.5000
Host Driver Initialization … PASS
Number of CA Ports Active … 0
Error Counter Check on CA #0 (VPI)… PASS
Kernel Syslog Check … PASS
Node GUID on CA #0 (VPI) … NA
------------------ DONE ---------------------
Is this configuration not supported? Any idea how to get a link up if it is?
Hello Steve,
Many thanks for posting your question on the Mellanox Community.
Based on the information provided, 56GbE is supported, but you need to force the speed on the switch to 56GbE. After that the link will come up on the ConnectX-3 at 56GbE.
Please update us if this resolves your issue.
Many thanks,
~Mellanox Technical Support
