No link with Connext X3 / Debian 10
Hi there, we have no connection with a connectX-3. No lights nothing. The card is found and the driver is installed. I´ve tried it with many cables, switches etc. All components are 10G. The cable is also shown in the compability list.
lspci | grep Mellanox
04:00.0 Ethernet controller: Mellanox Technologies MT27500 Family [ConnectX-3]
mst status
MST modules:
MST PCI module loaded
MST PCI configuration module loaded
MST devices:
/dev/mst/mt4099_pciconf0 - PCI configuration cycles access.
domain:bus:dev.fn=0000:04:00.0 addr.reg=88 data.reg=92 cr_bar.gw_offset=-1
Chip revision is: 01
/dev/mst/mt4099_pci_cr0 - PCI direct access.
domain:bus:dev.fn=0000:04:00.0 bar=0x93900000 size=0x100000
ethtool eno49
Settings for eno49:
Supported ports: [ FIBRE ]
Supported link modes: 1000baseKX/Full
10000baseKX4/Full
10000baseKR/Full
40000baseCR4/Full
40000baseSR4/Full
56000baseCR4/Full
56000baseSR4/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 1000baseKX/Full
10000baseKX4/Full
10000baseKR/Full
40000baseCR4/Full
40000baseSR4/Full
Advertised pause frame use: Symmetric
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Speed: Unknown!
Duplex: Unknown! (255)
Port: FIBRE
PHYAD: 0
Transceiver: internal
Auto-negotiation: off
Supports Wake-on: d
Wake-on: d
Current message level: 0x00000014 (20)
link ifdown
Link detected: no
It´s only a single port ethernet card with 10G but there a 2 ports… The newest firmware is installed.
Anyone an idea?
Hello Hermann,
Thank you for posting your question on the Mellanox Community.
We have a few questions to better understand the issue you are experiencing.
  1. Which version of the Mellanox OFED are you using? You can see the version installed with ofed_info -s
  2. What is the model number for the cable you are using?
  3. What is the topology of your setup? For example connected to a switch or back-to-back
  4. If you are using a switch what is the switch model number
  5. What model of adapter are you using? You can get this from the output of lspci -vvv and looking for the line “[V2] Vendor specific”
  6. What command are you using to bring up the interface? Please provide the output of this command.
  7. When you attempt to bring up the interface do you see any output in dmesg?
  8. Since you are trying to run at 10Gb you could test forcing the adapter to run at this speed. See the following article on the topic:
https://community.mellanox.com/s/article/howto-change-the-ethernet-port-speed-of-mellanox-adapters--linux-x
For example ethtool -s eno49 speed 10000 autoneg off
Thanks and regards,
~Mellanox Technical Support
