We have SAP HANA Database installed on Lenovo Servers, with Mellanox 10G Cards. We want to upgrade current 1G copper link to 10G mellanox. We got Fiber ran to ports on servers, but server is showing “No Link Detected”. Mellanox drivers are showing loaded. Could someone please advise why it’s showing like that? and if we can fix it?
eth102 is mellanox, and connected to 10G switch port via Fiber:
uswix340# ethtool eth102
Settings for eth102:
Supported ports: [ TP ]
Supported link modes: 10000baseT/Full
Supports auto-negotiation: No
Advertised link modes: 10000baseT/Full
Advertised pause frame use: No
Advertised auto-negotiation: No
Speed: Unknown!
Duplex: Unknown! (255)
Port: Twisted Pair
PHYAD: 0
Transceiver: internal
Auto-negotiation: off
MDI-X: Unknown
Supports Wake-on: d
Wake-on: d
Current message level: 0x00000014 (20)
link ifdown
Link detected: no
uswix340# ifplugstatus
lo: link beat detected
usb0: link beat detected
eth4: link beat detected
eth5: unplugged
usb1: link beat detected
eth6: unplugged
eth7: link beat detected
eth8: unplugged
eth9: unplugged
eth10: unplugged
eth11: link beat detected
eth100: unplugged
eth101: unplugged
eth102: unplugged
eth103: unplugged
bond2: link beat detected
uswix340#
uswix340# lspci | grep Mellanox
31:00.0 Ethernet controller: Mellanox Technologies MT27500 Family [ConnectX-3]
a1:00.0 Ethernet controller: Mellanox Technologies MT27500 Family [ConnectX-3]
uswix340#
uswix340# /sbin/connectx_port_config -s
Port configuration for PCI device: 0000:31:00.0 is:
eth
eth
Port configuration for PCI device: 0000:a1:00.0 is:
auto (eth)
auto (eth)
uswix340# mst status
MST modules:
MST PCI module loaded
MST PCI configuration module loaded
MST devices:
/dev/mst/mt4099_pciconf0 - PCI configuration cycles access.
domain:bus:dev.fn=0000:31:00.0 addr.reg=88 data.reg=92
Chip revision is: 01
/dev/mst/mt4099_pciconf1 - PCI configuration cycles access.
domain:bus:dev.fn=0000:a1:00.0 addr.reg=88 data.reg=92
/dev/mst/mt4099_pci_cr0 - PCI direct access.
domain:bus:dev.fn=0000:31:00.0 bar=0xdf700000 size=0x100000
/dev/mst/mt4099_pci_cr1 - PCI direct access.
domain:bus:dev.fn=0000:a1:00.0 bar=0xf2700000 size=0x100000
uswix340#
137: PCI a100.0: 0200 Ethernet controller
[Created at pci.323]
UDI: /org/freedesktop/Hal/devices/pci_15b3_1003_0
Unique ID: nYg+.mx8SyyVVYd6
Parent ID: vcUh.B6xqWRvtaZ0
SysFS ID: /devices/pci0000:a0/0000:a0:02.0/0000:a1:00.0
SysFS BusID: 0000:a1:00.0
Hardware Class: network
Model: “Mellanox MT27500 Family [ConnectX-3]”
Vendor: pci 0x15b3 “Mellanox Technologies”
Device: pci 0x1003 “MT27500 Family [ConnectX-3]”
SubVendor: pci 0x15b3 “Mellanox Technologies”
SubDevice: pci 0x0077
Driver: “mlx4_core”
Driver Modules: “mlx4_core”
Device File: eth102
Memory Range: 0xf2700000-0xf27fffff (rw,non-prefetchable)
Memory Range: 0xf3800000-0xf3ffffff (ro,non-prefetchable)
IRQ: 272 (no events)
HW Address: 7c:fe:90:1a:b2:40
Link detected: no
Module Alias: “pci:v000015B3d00001003sv000015B3sd00000077bc02sc00i00”
Driver Info #0:
Driver Status: mlx4_core is active
Driver Activation Cmd: “modprobe mlx4_core”
Config Status: cfg=no, avail=yes, need=no, active=unknown
Attached to: #122 (PCI bridge)
