ConnectX-6 Dx not setting MAC
I’ve an issue where a ConnectX-6 Dx has a MAC configured according to flint, but it’s not showing in Linux (Ubuntu 24.04 using doca-host_3.2.1).
Device and Firmware info:
$ sudo mlxfwmanager --online
Querying Mellanox devices firmware ...
Device #1:
  Device Type:      ConnectX6DX
  Part Number:      MCX623106AN-CDA_Ax
  Description:      ConnectX-6 Dx EN adapter card; 100GbE; Dual-port QSFP56; PCIe 4.0/3.0 x16;
  PSID:             MT_0000000359
  PCI Device Name:  /dev/mst/mt4125_pciconf0
  Base GUID:        c46237000003015c
  Base MAC:         c4623703015c
  Versions:         Current        Available
     FW             22.47.1088     22.43.1014
     PXE            3.8.0201       3.7.0500
     UEFI           14.40.0010     14.36.0016
  Status:           Up to date
If we check flint, we see that a Base MAC is configured
$ sudo flint -d 03:00.0 query
Image type:            FS4
FW Version:            22.47.1088
FW Release Date:       9.12.2025
Product Version:       22.47.1088
Rom Info:              type=UEFI version=14.40.10 cpu=AMD64,AARCH64
                       type=PXE version=3.8.201 cpu=AMD64
Description:           UID                GuidsNumber
Base GUID:             c46237000003015c        4
Base MAC:              c4623703015c            4
Image VSD:             N/A
Device VSD:            N/A
PSID:                  MT_0000000359
Security Attributes:   N/A
If we check ip dev we see a all zero’s-mac:
$ ip link show dev ens2f0np0
6: ens2f0np0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
    link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff
    altname enp3s0f0np0
How can this be fixed?
Hi
This is a kernel related issue, you can change it manually.
The mac address should be: c4:62:37:03:01:5d
You can also check udev relate configuration to check why the kernel cause the issue.
Thanks,
Suo
