constexpr array in device code
could you please tell me, is there any way to use constexpr arrays in device code ? According to “Cuda C programming guide 7.0” I have no problems with constexpr scalars, but arrays seem do not compile. Below some example:
template<unsigned D, unsigned Q>
class LatticeArrangement
template<>
class LatticeArrangement<3,19>
	public:
		static constexpr double c[19] = { 0,1,2,3,4,5,6,7,8,9,10,
																			11,12,13,14,15,16,17,18 } ;
		static constexpr double d = 19.0 ;
		__host__ __device__
		static constexpr double getC( unsigned index )
			// FIXME: error: identifier "LatticeArrangement<(unsigned int)3u, (unsigned int)19u> ::c" is undefined in device code
			return c[ index ] ;
			//return d * index ; // OK, this one works
constexpr double LatticeArrangement<3,19>::c[] ;
template< class LatticeArrangement >
class FluidModelIncompressible
	public:
		__host__ __device__
		static double computeSomething(double v, unsigned idx)
			return LatticeArrangement::getC( idx ) * v ;
// Does nothing useful, we want only to compile this
template< class FluidModel >
__global__ void
kernel1 ( double * data )
	data[ threadIdx.x ] = FluidModel::computeSomething( threadIdx.y, threadIdx.z ) ;
int main( int argc, char ** argv )
	dim3 numBlocks  ( 2 ) ;
	dim3 numThreads ( 4, 4, 4 ) ;
	double * vptr = NULL ;
	kernel1< FluidModelIncompressible< LatticeArrangement<3,19> > >
		<<< numBlocks, numThreads >>> 	( vptr ) ;
	return 0 ;
Maybe there is some other way to avoid duplication of code between host and device ?
I am using
Copyright (c) 2005-2015 NVIDIA Corporation
Built on Mon_Feb_16_22:59:02_CST_2015
Cuda compilation tools, release 7.0, V7.0.27
Thanks in advance :)
