I am trying to partially specialize some functions with some number of float arguments to match the type float (*)(float). These functions represent probability density functions and my main calculation kernel takes a variadic number of these function pointers for the calculation. The specific probability density functions I am using have 2 extra float args though which parameterize the distribution. These 2 floats are known at compile time, so I find it not unreasonable to think that it should be possible to construct a constexpr function pointer to a density function with 2 of 3 parameters specialized already.
For example in the following code (which compiles with g++ 12.1 once I remove the __host__ and __device__) I am trying to specialize the arguments a and c from R2WoodsSaxon and get back a constexpr function pointer which can be passed to further templates.
#include <iostream>
#include <cmath>
#include <array>
#include <utility>
typedef float (*PDF)(float);
// r^2 * Woods Saxon Distribution
__host__ __device__
float R2WoodsSaxon(float r, float a, float c)
if (r < 0.0f) return 0.0f;
return r * r / (1 + expf( (r - c) / a ));
// r^2 * Gaussian Distribution
__host__ __device__
float R2Gaussian(float r, float variance) {
return r * r * expf(- r * r / (2 * variance));
template <const auto pdfFunction, const auto& arr, typename = void>
struct FunctionSpecializerHelper;
template <const auto pdfFunction, const auto& arr, std::size_t... i>
struct FunctionSpecializerHelper<pdfFunction, arr, std::index_sequence< i... > > {
constexpr static PDF type = [] __host__ __device__ (float r) -> float {return pdfFunction(r, arr.at( i )...); };
template <const auto pdfFunction, const auto& arr>
struct FunctionSpecializer {
constexpr static PDF type = FunctionSpecializerHelper<pdfFunction, arr, std::make_index_sequence<arr.size()> >::type;
int main() {
constexpr static std::array<float, 2> arr = {2.f, 0.54f};
constexpr static auto func = FunctionSpecializer<R2WoodsSaxon, arr>::type;
std::cout << func(1) << std::endl;
return 0;
I’m not sure why this code compiles with g++ but fails to compile using nvcc. But this is also only one issue! Using a workaround to try and generate similar results with a static member function of a template struct shows that there are further issues.
#include <iostream>
#include <cmath>
#include <array>
#include <utility>
__host__ __device__
template<const auto pdfFunction, const auto& arr>
struct Functor
__device__ __host__
constexpr Functor() {}
__device__ __host__
static float Call(float r) { return pdfFunction(r, arr.at(0), arr.at(1) ); }
int main() {
constexpr static auto func = Functor<R2WoodsSaxon, arr>().Call;
return 0;
This compiles fine because the generated function pointer is only being used on the host, but as soon as that function pointer is passed to a device function the compilation fails and I receive some very cryptic error messages. The below attached image is from a different version of the code, but the errors are the same.
For whatever reason the compiler is not able to pull the values from the
std::array and put them into the function pointer and only fails compiling after already mangling all the function names.
Is this sort of operation just not possible? I can partially specialize the function myself by hardcoding a new function which just calls the more general distribution function but with hardcoded values, so if it is absolutely impossible to do what I am trying to do I could write some script to automatically generate me code for a given set of desired probability densities. Obviously that is somewhat less than optimal so I would like to be able to programmatically generate these function pointers.
Any tips?
