If you are reporting a bug or error, consider submitting a Support Bundle to aiworkbench-ea@nvidia.com. This will help us solve your issue more quickly.
Please describe your issue or request: (tick the boxes after creating this topic):
Please tick the appropriate box to help us categorize your post
Bug or Error
Feature Request
Documentation Issue
Other
Hi everyone,
After system recovery, I am trying to setup my nvidia ai workbench on dgx spark.
During the installing and updating packages process, I encountered container toolkits install workflow failed error. The error log is attached belowed. Any help will be appreciated!
workbench.log (64.6 KB)
Hello, this is reading like a temporary network issue from the logs (Could not resolve host: nvidia.github.io\ngpg) . Could you please confirm if this is still failing for you?
WIthout VPN or VPS, I cannot access GitHub in China. I suspect maybe that’s why the installation was failed. I am thinking to use VPS + FRP if it will help me solve the network issue.
Yeah, so it’s still failing for me. For the container toolkits workflow installing part, it got stuck at 91-94%. Here is the error log.
workbench-2.log (141.4 KB)
Also when I used nvidia sync on my mac to launch ai workbench, in my terminal the error message is : error while executing install workflow
│ Check log files for output:
│ /home/vic/.nvwb/logs/nvwb.log
│ /home/vic/.nvwb/logs/workbench.log
Error:
an error occurred during the install process: exit status 1
Setup failed. Review logs and relaunch “AI Workbench” to try install again.
When I tried to add remote location on ai workbench on my mac, it also cannot work.
I also tried to uninstall and reinstall ai workbench on dgx spark but it still has the same issue.
It turns out it was a network issue. After I set up VPS with SSH tunneling and system proxy on dgx spark, I was able to get it resolved.
Thank you for letting us know and we’re glad you were able to get it working.
