Something happened, please contact support or try restarting the application and installer. I am using the latest version and facing this issue…
Thanks for posting.
Can you go here to see how to create logs?
Log and Runtime Files - NVIDIA Docs
Then, send them to aiworkbench-ea@nvidia.com
This will help us diagnose.
I believe you do not have Windows Subsystem for Linux enabled in the Windows ‘Add Feature’ dialog. Once you check-mark to enable reboot your system. Shown here,
Once the system restarts install Docker Desktop for Windows and make sure it is upgraded to version 4.34.2, https://docs.docker.com/desktop/install/windows-install/ Once installed check settings menu (Gear at the top of the menubar) for software updates and upgrade to 4.34.2 before installing Ai Workbench.
