BARO
1
Hi everyone.
I’m trying to send to RVIZ the image captured from jetson-inference.
The problem is the format of the image.
RVIZ support RGB8 and the image who provide from the jetson-inference library offer FLOAT32 with 4 channels image.
I’m trying to use this code:
cv::Mat image = cv::Mat(camera->GetWidth(),camera->GetHeight(),CV_32FC4, imgRGBA);
cv::Mat imgrgb;
cv::cvtColor(image,imgrgb, cv::COLOR_RGBA2BGR);
header.seq = count; // user defined counter
header.stamp = ros::Time::now(); // time
img_bridge = cv_bridge::CvImage(header, sensor_msgs::image_encodings::BGR8, imgrgb);
img_bridge.toImageMsg(img_msg); // from cv_bridge to sensor_msgs::Image
Best Regards
Gabriel
BARO
2
Solution:
while (n.ok() && !signal_recieved )
float* imgRGBA = NULL;
void* imgCPU = NULL;
void* imgCUDA = NULL;
float* imgRGBAX = NULL;
if (!camera->Capture(&imgCPU,&imgCUDA,1000))
printf("\nCamera Failed\n");
if (!camera->ConvertRGBA(imgCUDA,&imgRGBA,true)) {
printf("Failed to convert image/n");
detectNet::Detection* detections = NULL;
const int numDetections = net->Detect(imgRGBA, camera->GetWidth(), camera->GetHeight(), &detections);
counter = counter+1;
printf(" %f \n",counter);
cv::Mat im=cv::Mat(mHeight,mWidth,CV_32FC4, imgRGBA);
if (counter>=5)
counter=0;
cv_bridge::CvImage img_bridge;
std_msgs::Header header;
header.seq=counter;
img_bridge = cv_bridge::CvImage(header,sensor_msgs::image_encodings::RGBA8,im);
pub.publish(img_msg);
SAFE_DELETE(camera);
kayccc
3
Cool! Thanks for sharing!
