Sorry for the late update.
Our Caffe parser doesn’t support Flatten layer.
However, you can use Reshape layer to do the identical transform instead.
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
There is another issue in your model, please add one more output in the detection_out layer to match the DetectionOutput plugin requirement.
top: "keep_count"
A similar change can also be found in our SSD sample:
/usr/src/tensorrt/samples/sampleSSD/
Expecting you are using the model shared in the below GitHub, we also make an workable deploy.prototxt for you:
https://github.com/spmallick/learnopencv/tree/master/FaceDetectionComparison/models
input: "data"
input_shape {
dim: 1
dim: 3
dim: 300
dim: 300
layer {
type: "BatchNorm"
bottom: "data"
top: "data_bn"
param {
lr_mult: 0.0
param {
lr_mult: 0.0
param {
lr_mult: 0.0
layer {
type: "Scale"
bottom: "data_bn"
top: "data_bn"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 1.0
scale_param {
bias_term: true
layer {
type: "Convolution"
bottom: "data_bn"
top: "conv1_h"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 1.0
convolution_param {
num_output: 32
pad: 3
kernel_size: 7
stride: 2
weight_filler {
type: "msra"
variance_norm: FAN_OUT
bias_filler {
type: "constant"
value: 0.0
layer {
type: "BatchNorm"
bottom: "conv1_h"
top: "conv1_h"
param {
lr_mult: 0.0
param {
lr_mult: 0.0
param {
lr_mult: 0.0
layer {
type: "Scale"
bottom: "conv1_h"
top: "conv1_h"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 1.0
scale_param {
bias_term: true
layer {
type: "ReLU"
bottom: "conv1_h"
top: "conv1_h"
layer {
type: "Pooling"
bottom: "conv1_h"
top: "conv1_pool"
pooling_param {
kernel_size: 3
stride: 2
layer {
type: "Convolution"
bottom: "conv1_pool"
top: "layer_64_1_conv1_h"
param {
lr_mult: 1.0
decay_mult: 1.0
convolution_param {
num_output: 32
bias_term: false
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: "msra"
bias_filler {
type: "constant"
value: 0.0
layer {
type: "BatchNorm"
bottom: "layer_64_1_conv1_h"
param {
lr_mult: 0.0
param {
lr_mult: 0.0
param {
lr_mult: 0.0
layer {
type: "Scale"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 1.0
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "layer_64_1_conv2_h"
param {
lr_mult: 1.0
decay_mult: 1.0
convolution_param {
num_output: 32
bias_term: false
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: "msra"
bias_filler {
type: "constant"
value: 0.0
layer {
type: "Eltwise"
bottom: "layer_64_1_conv2_h"
top: "layer_64_1_sum"
layer {
type: "BatchNorm"
bottom: "layer_64_1_sum"
top: "layer_128_1_bn1_h"
param {
lr_mult: 0.0
param {
lr_mult: 0.0
param {
lr_mult: 0.0
layer {
type: "Scale"
bottom: "layer_128_1_bn1_h"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 1.0
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "layer_128_1_conv1_h"
param {
lr_mult: 1.0
decay_mult: 1.0
convolution_param {
num_output: 128
bias_term: false
pad: 1
kernel_size: 3
stride: 2
weight_filler {
type: "msra"
bias_filler {
type: "constant"
value: 0.0
layer {
type: "BatchNorm"
bottom: "layer_128_1_conv1_h"
param {
lr_mult: 0.0
param {
lr_mult: 0.0
param {
lr_mult: 0.0
layer {
type: "Scale"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 1.0
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "layer_128_1_conv2"
param {
lr_mult: 1.0
decay_mult: 1.0
convolution_param {
num_output: 128
bias_term: false
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: "msra"
bias_filler {
type: "constant"
value: 0.0
layer {
type: "Convolution"
top: "layer_128_1_conv_expand_h"
param {
lr_mult: 1.0
decay_mult: 1.0
convolution_param {
num_output: 128
bias_term: false
pad: 0
kernel_size: 1
stride: 2
weight_filler {
type: "msra"
bias_filler {
type: "constant"
value: 0.0
layer {
type: "Eltwise"
bottom: "layer_128_1_conv2"
bottom: "layer_128_1_conv_expand_h"
top: "layer_128_1_sum"
layer {
type: "BatchNorm"
bottom: "layer_128_1_sum"
top: "layer_256_1_bn1"
param {
lr_mult: 0.0
param {
lr_mult: 0.0
param {
lr_mult: 0.0
layer {
type: "Scale"
bottom: "layer_256_1_bn1"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 1.0
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "layer_256_1_conv1"
param {
lr_mult: 1.0
decay_mult: 1.0
convolution_param {
num_output: 256
bias_term: false
pad: 1
kernel_size: 3
stride: 2
weight_filler {
type: "msra"
bias_filler {
type: "constant"
value: 0.0
layer {
type: "BatchNorm"
bottom: "layer_256_1_conv1"
param {
lr_mult: 0.0
param {
lr_mult: 0.0
param {
lr_mult: 0.0
layer {
type: "Scale"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 1.0
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "layer_256_1_conv2"
param {
lr_mult: 1.0
decay_mult: 1.0
convolution_param {
num_output: 256
bias_term: false
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: "msra"
bias_filler {
type: "constant"
value: 0.0
layer {
type: "Convolution"
top: "layer_256_1_conv_expand"
param {
lr_mult: 1.0
decay_mult: 1.0
convolution_param {
num_output: 256
bias_term: false
pad: 0
kernel_size: 1
stride: 2
weight_filler {
type: "msra"
bias_filler {
type: "constant"
value: 0.0
layer {
type: "Eltwise"
bottom: "layer_256_1_conv2"
bottom: "layer_256_1_conv_expand"
top: "layer_256_1_sum"
layer {
type: "BatchNorm"
bottom: "layer_256_1_sum"
top: "layer_512_1_bn1"
param {
lr_mult: 0.0
param {
lr_mult: 0.0
param {
lr_mult: 0.0
layer {
type: "Scale"
bottom: "layer_512_1_bn1"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 1.0
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "layer_512_1_conv1_h"
param {
lr_mult: 1.0
decay_mult: 1.0
convolution_param {
num_output: 128
bias_term: false
pad: 1
kernel_size: 3
stride: 1 # 2
weight_filler {
type: "msra"
bias_filler {
type: "constant"
value: 0.0
layer {
type: "BatchNorm"
bottom: "layer_512_1_conv1_h"
param {
lr_mult: 0.0
param {
lr_mult: 0.0
param {
lr_mult: 0.0
layer {
type: "Scale"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 1.0
scale_param {
bias_term: true
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "layer_512_1_conv2_h"
param {
lr_mult: 1.0
decay_mult: 1.0
convolution_param {
num_output: 256
bias_term: false
pad: 2 # 1
kernel_size: 3
stride: 1
dilation: 2
weight_filler {
type: "msra"
bias_filler {
type: "constant"
value: 0.0
layer {
type: "Convolution"
top: "layer_512_1_conv_expand_h"
param {
lr_mult: 1.0
decay_mult: 1.0
convolution_param {
num_output: 256
bias_term: false
pad: 0
kernel_size: 1
stride: 1 # 2
weight_filler {
type: "msra"
bias_filler {
type: "constant"
value: 0.0
layer {
type: "Eltwise"
bottom: "layer_512_1_conv2_h"
bottom: "layer_512_1_conv_expand_h"
top: "layer_512_1_sum"
layer {
type: "BatchNorm"
bottom: "layer_512_1_sum"
param {
lr_mult: 0.0
param {
lr_mult: 0.0
param {
lr_mult: 0.0
layer {
type: "Scale"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 1.0
scale_param {
bias_term: true
layer {
type: "ReLU"
top: "fc7"
layer {
type: "Convolution"
bottom: "fc7"
top: "conv6_1_h"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 0
kernel_size: 1
stride: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0
layer {
type: "ReLU"
bottom: "conv6_1_h"
top: "conv6_1_h"
layer {
type: "Convolution"
bottom: "conv6_1_h"
top: "conv6_2_h"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
pad: 1
kernel_size: 3
stride: 2
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0
layer {
type: "ReLU"
bottom: "conv6_2_h"
top: "conv6_2_h"
layer {
type: "Convolution"
bottom: "conv6_2_h"
top: "conv7_1_h"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
pad: 0
kernel_size: 1
stride: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0
layer {
type: "ReLU"
bottom: "conv7_1_h"
top: "conv7_1_h"
layer {
type: "Convolution"
bottom: "conv7_1_h"
top: "conv7_2_h"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 1
kernel_size: 3
stride: 2
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0
layer {
type: "ReLU"
bottom: "conv7_2_h"
top: "conv7_2_h"
layer {
type: "Convolution"
bottom: "conv7_2_h"
top: "conv8_1_h"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
pad: 0
kernel_size: 1
stride: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0
layer {
type: "ReLU"
bottom: "conv8_1_h"
top: "conv8_1_h"
layer {
type: "Convolution"
bottom: "conv8_1_h"
top: "conv8_2_h"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0
layer {
type: "ReLU"
bottom: "conv8_2_h"
top: "conv8_2_h"
layer {
type: "Convolution"
bottom: "conv8_2_h"
top: "conv9_1_h"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
pad: 0
kernel_size: 1
stride: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0
layer {
type: "ReLU"
bottom: "conv9_1_h"
top: "conv9_1_h"
layer {
type: "Convolution"
bottom: "conv9_1_h"
top: "conv9_2_h"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0
layer {
type: "ReLU"
bottom: "conv9_2_h"
top: "conv9_2_h"
layer {
type: "Normalize"
top: "conv4_3_norm"
norm_param {
across_spatial: false
scale_filler {
type: "constant"
value: 20
channel_shared: false
layer {
type: "Convolution"
bottom: "conv4_3_norm"
top: "conv4_3_norm_mbox_loc"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 16
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0
layer {
type: "Permute"
bottom: "conv4_3_norm_mbox_loc"
top: "conv4_3_norm_mbox_loc_perm"
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: "Reshape"
bottom: "conv4_3_norm_mbox_loc_perm"
top: "conv4_3_norm_mbox_loc_flat"
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: "Convolution"
top: "conv4_3_norm_mbox_conf"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 8 # 84
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0
layer {
type: "Permute"
bottom: "conv4_3_norm_mbox_conf"
top: "conv4_3_norm_mbox_conf_perm"
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: "Reshape"
bottom: "conv4_3_norm_mbox_conf_perm"
top: "conv4_3_norm_mbox_conf_flat"
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: "PriorBox"
bottom: "data"
top: "conv4_3_norm_mbox_priorbox"
prior_box_param {
min_size: 30.0
max_size: 60.0
aspect_ratio: 2
flip: true
clip: false
variance: 0.1
variance: 0.1
variance: 0.2
variance: 0.2
step: 8
offset: 0.5
layer {
type: "Convolution"
bottom: "fc7"
top: "fc7_mbox_loc"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 24
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0
layer {
type: "Permute"
bottom: "fc7_mbox_loc"
top: "fc7_mbox_loc_perm"
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: "Reshape"
bottom: "fc7_mbox_loc_perm"
top: "fc7_mbox_loc_flat"
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: "Convolution"
bottom: "fc7"
top: "fc7_mbox_conf"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 12 # 126
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0
layer {
type: "Permute"
bottom: "fc7_mbox_conf"
top: "fc7_mbox_conf_perm"
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: "Reshape"
bottom: "fc7_mbox_conf_perm"
top: "fc7_mbox_conf_flat"
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: "PriorBox"
bottom: "fc7"
bottom: "data"
top: "fc7_mbox_priorbox"
prior_box_param {
min_size: 60.0
max_size: 111.0
aspect_ratio: 2
aspect_ratio: 3
flip: true
clip: false
variance: 0.1
variance: 0.1
variance: 0.2
variance: 0.2
step: 16
offset: 0.5
layer {
type: "Convolution"
bottom: "conv6_2_h"
top: "conv6_2_mbox_loc"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 24
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0
layer {
type: "Permute"
bottom: "conv6_2_mbox_loc"
top: "conv6_2_mbox_loc_perm"
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: "Reshape"
bottom: "conv6_2_mbox_loc_perm"
top: "conv6_2_mbox_loc_flat"
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: "Convolution"
bottom: "conv6_2_h"
top: "conv6_2_mbox_conf"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0
layer {
type: "Permute"
bottom: "conv6_2_mbox_conf"
top: "conv6_2_mbox_conf_perm"
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: "Reshape"
bottom: "conv6_2_mbox_conf_perm"
top: "conv6_2_mbox_conf_flat"
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: "PriorBox"
bottom: "conv6_2_h"
bottom: "data"
top: "conv6_2_mbox_priorbox"
prior_box_param {
min_size: 111.0
max_size: 162.0
aspect_ratio: 2
aspect_ratio: 3
flip: true
clip: false
variance: 0.1
variance: 0.1
variance: 0.2
variance: 0.2
step: 32
offset: 0.5
layer {
type: "Convolution"
bottom: "conv7_2_h"
top: "conv7_2_mbox_loc"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 24
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0
layer {
type: "Permute"
bottom: "conv7_2_mbox_loc"
top: "conv7_2_mbox_loc_perm"
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: "Reshape"
bottom: "conv7_2_mbox_loc_perm"
top: "conv7_2_mbox_loc_flat"
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: "Convolution"
bottom: "conv7_2_h"
top: "conv7_2_mbox_conf"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0
layer {
type: "Permute"
bottom: "conv7_2_mbox_conf"
top: "conv7_2_mbox_conf_perm"
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: "Reshape"
bottom: "conv7_2_mbox_conf_perm"
top: "conv7_2_mbox_conf_flat"
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: "PriorBox"
bottom: "conv7_2_h"
bottom: "data"
top: "conv7_2_mbox_priorbox"
prior_box_param {
min_size: 162.0
max_size: 213.0
aspect_ratio: 2
aspect_ratio: 3
flip: true
clip: false
variance: 0.1
variance: 0.1
variance: 0.2
variance: 0.2
step: 64
offset: 0.5
layer {
type: "Convolution"
bottom: "conv8_2_h"
top: "conv8_2_mbox_loc"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 16
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0
layer {
type: "Permute"
bottom: "conv8_2_mbox_loc"
top: "conv8_2_mbox_loc_perm"
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: "Reshape"
bottom: "conv8_2_mbox_loc_perm"
top: "conv8_2_mbox_loc_flat"
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: "Convolution"
bottom: "conv8_2_h"
top: "conv8_2_mbox_conf"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 8 # 84
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0
layer {
type: "Permute"
bottom: "conv8_2_mbox_conf"
top: "conv8_2_mbox_conf_perm"
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: "Reshape"
bottom: "conv8_2_mbox_conf_perm"
top: "conv8_2_mbox_conf_flat"
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: "PriorBox"
bottom: "conv8_2_h"
bottom: "data"
top: "conv8_2_mbox_priorbox"
prior_box_param {
min_size: 213.0
max_size: 264.0
aspect_ratio: 2
flip: true
clip: false
variance: 0.1
variance: 0.1
variance: 0.2
variance: 0.2
step: 100
offset: 0.5
layer {
type: "Convolution"
bottom: "conv9_2_h"
top: "conv9_2_mbox_loc"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 16
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0
layer {
type: "Permute"
bottom: "conv9_2_mbox_loc"
top: "conv9_2_mbox_loc_perm"
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: "Reshape"
bottom: "conv9_2_mbox_loc_perm"
top: "conv9_2_mbox_loc_flat"
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: "Convolution"
bottom: "conv9_2_h"
top: "conv9_2_mbox_conf"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 8 # 84
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0
layer {
type: "Permute"
bottom: "conv9_2_mbox_conf"
top: "conv9_2_mbox_conf_perm"
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: "Reshape"
bottom: "conv9_2_mbox_conf_perm"
top: "conv9_2_mbox_conf_flat"
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: "PriorBox"
bottom: "conv9_2_h"
bottom: "data"
top: "conv9_2_mbox_priorbox"
prior_box_param {
min_size: 264.0
max_size: 315.0
aspect_ratio: 2
flip: true
clip: false
variance: 0.1
variance: 0.1
variance: 0.2
variance: 0.2
step: 300
offset: 0.5
layer {
type: "Concat"
bottom: "conv4_3_norm_mbox_loc_flat"
bottom: "fc7_mbox_loc_flat"
bottom: "conv6_2_mbox_loc_flat"
bottom: "conv7_2_mbox_loc_flat"
bottom: "conv8_2_mbox_loc_flat"
bottom: "conv9_2_mbox_loc_flat"
top: "mbox_loc"
concat_param {
axis: 1
layer {
type: "Concat"
bottom: "conv4_3_norm_mbox_conf_flat"
bottom: "fc7_mbox_conf_flat"
bottom: "conv6_2_mbox_conf_flat"
bottom: "conv7_2_mbox_conf_flat"
bottom: "conv8_2_mbox_conf_flat"
bottom: "conv9_2_mbox_conf_flat"
top: "mbox_conf"
concat_param {
axis: 1
layer {
type: "Concat"
bottom: "conv4_3_norm_mbox_priorbox"
bottom: "fc7_mbox_priorbox"
bottom: "conv6_2_mbox_priorbox"
bottom: "conv7_2_mbox_priorbox"
bottom: "conv8_2_mbox_priorbox"
bottom: "conv9_2_mbox_priorbox"
top: "mbox_priorbox"
concat_param {
axis: 2
layer {
type: "Reshape"
bottom: "mbox_conf"
top: "mbox_conf_reshape"
reshape_param {
shape {
dim: 0
dim: -1
dim: 2
layer {
type: "Softmax"
bottom: "mbox_conf_reshape"
top: "mbox_conf_softmax"
softmax_param {
axis: 2
layer {
type: "Reshape"
bottom: "mbox_conf_softmax"
top: "mbox_conf_flatten"
reshape_param {
shape {
dim: 0
dim: -1
dim: 1
dim: 1
layer {
type: "DetectionOutput"
bottom: "mbox_loc"
bottom: "mbox_conf_flatten"
bottom: "mbox_priorbox"
top: "detection_out"
top: "keep_count"
include {
phase: TEST
detection_output_param {
num_classes: 2
share_location: true
background_label_id: 0
nms_param {
nms_threshold: 0.3
top_k: 400
code_type: CENTER_SIZE
keep_top_k: 200
confidence_threshold: 0.01
