vcb1
January 26, 2022, 2:27pm
#1
I want to adapt the source code for the object tracker example in the VisionWorks library (VisionWorks-1.6-Samples/samples/object_tracker_nvxcu) to use it in my own code.
Therefore, i am trying to call the tracker using my own images in cv::cuda::GpuMat, i can convert them to vx_image but i do not know how to convert it to nvxcu_image_t in order to follow the same structure as the one defined in main_object_tracker_nvxcu.cpp.
i found a similar post Need help to convert nvxcu_pitch_linear_image_t image to vx_image , but it is not exactlly the same and i could not find a solution.
Many thanks,
vcb1
February 2, 2022, 11:39am
#2
After some research i solve the problem…i posted here the solution in case is useful for someone else.
In order to go from cv::mat or cv:cuda:GpuMat to nvxcu_pitch_linear_image_t i have modified the function createImage that is included in the example.
Here the code for the modified functions:
size_t getPixelBytes(int type)
switch(type)
case CV_8UC1:
case CV_8UC3:
return sizeof(uint8_t);
break;
case CV_16UC1:
case CV_16UC3:
return sizeof(uint16_t);
break;
case CV_32FC1:
case CV_32FC3:
return sizeof(float);
break;
case CV_64FC1:
case CV_64FC3:
return sizeof(double);
break;
default:
return 0;
nvxcu_pitch_linear_image_t createImageFromGpuMat(uint32_t width, uint32_t height, nvxcu_df_image_e format, cv::cuda::GpuMat frame)
NVXIO_ASSERT(format == NVXCU_DF_IMAGE_U8 ||
format == NVXCU_DF_IMAGE_RGB ||
format == NVXCU_DF_IMAGE_RGBX);
nvxcu_pitch_linear_image_t image = { };
image.base.format = format;
image.base.image_type = NVXCU_PITCH_LINEAR_IMAGE;
image.base.width = width;
image.base.height = height;
size_t pitch = 0ul;
uint32_t cn = format == NVXCU_DF_IMAGE_U8 ? 1u :
format == NVXCU_DF_IMAGE_RGB ? 3u : 4u;
NVXIO_CUDA_SAFE_CALL( cudaMallocPitch(&image.planes[0].dev_ptr, &pitch,image.base.width * cn, image.base.height) );
image.planes[0].pitch_in_bytes = static_cast<uint32_t>(pitch);
//Get number of bytes occupied by a single pixel. Although VideoCapture mostly returns CV_8UC3 type frame thus pixelBytes is 1 , but just in case.
size_t pixelBytes = getPixelBytes(frame.type());
//Number of actual data bytes occupied by a row.
size_t frameRowBytes = frame.cols * frame.channels() * pixelBytes;
cudaMemcpy2D(image.planes[0].dev_ptr, pitch, frame.ptr(), frame.step, frameRowBytes, frame.rows, cudaMemcpyHostToDevice);
return image;
nvxcu_pitch_linear_image_t createImageFromCvMat(uint32_t width, uint32_t height, nvxcu_df_image_e format, cv::Mat frame)
size_t pitch = 0ul;
return image;
system
closed
February 16, 2022, 11:39am
#3
