his @Morganh
I have trained an object detection model using mmdet hrnet. To run it on DeepStream I have created an engine file using mmdet2trt converter (GitHub - grimoire/mmdetection-to-tensorrt: convert mmdetection model to tensorrt, support fp16, int8, batch input, dynamic shape etc.). I got the engine file successfully from it.
Config which I am using for it is :
config_infer_primary_fasterRCNN.txt
after running the DeepStream command I am getting this error:
Any help is appreciated.
thanks
