I would like to learn the suggested way to convert NvMediaImage data with Block-Linear surface layout (for a semi-planar YUV 420) into Pitch-Linear surface layout, by using NvMedia libraries in Drive OS 5.2
The purpose is to be able to directly feed the output of the ISP0/1 into the jpeg encoder, which seems to accept only Pitch-Linear surface layout.
where imageFrame is allocated with NvMediaImageCreateNew, with a pitch linear surface layout, and imagePtr is obtained from the output buffer of ISP0, which is in block linear surface layout.
This seems to work, since I can use imageFrame with NvMediaIJPEFeedFrame. However, I’m not sure if this way of blitting is the most efficient way to use the hardware.
However, since I’m using 5.1.9 and not 5.2, I cannot get an explicit answer. But it seems like to in order to avoid blitting to convert block linear to pitch linear, you can configure the camera master instead.
