Converting .trt model to .etlt
• Hardware Platform (Jetson / GPU) agx orin
• DeepStream Version 6.2
• JetPack Version (valid for Jetson only) 5.1
• TensorRT Version 8.5.2
Hello, I know that deep stream config files only support .etlt files. I have a custom model which I converted successfully to .trt but is there a specific way to convert this model from .trt to .etlt which is supported by DS.
As far as I know, the conversion from etlt model file to TensorRT engine file is a one-way conversion, you cannot convert it back.
I have model.ONNX file is there a way to covert it to .etlt. Following NVIDIA documentation generates .trt file not .etlt
Why do you want to convert onnx model to etlt model? etlt model is a specially encrypted TAO model, and the encryption method is not public.
If you want to use onnx model in deepstream, you can use it directly in deepstream (refer option onnx-file in nvinfer config).
but won’t using TRT version of the model makes it more optimized? or i will get the same performance with the .ONNX file?
ONNX & TLT are formats of models, the TRT engine is created from the model, and the performance is evaluated on the engine file.
