is there a way to copy data with Jetson Nano through usb-c while in “Device Mode”. I indeed deal with sensitive data so that neither the jetson nano nor the computer that will send data are connected through a network.
Best regards,
Paul
Best regards,
Paul
What is the “usb-c” here?
The flash port on jetson nano is able to run as device mode and enable the usb network interface as 192.168.55.x. You could use that IP to transfer data to host.
