Correct config for training and deploying Efficientnet classification model in deepstream?
• Hardware Platform (Jetson / GPU) → GPU
• DeepStream Version → 5.1
• TensorRT Version → 7.2
• NVIDIA GPU Driver Version (valid for GPU only) → 455.32.00
• Issue Type( questions, new requirements, bugs) How to correctly setup the spec file for training Efficientnet classification model and the inference specs for using Efficientnet image classification model in Deepstream
classification_dvd_spec.cfg (1.3 KB)
sgie_efficientnet_tlt_config.txt (2.9 KB)
The inference result produced by Deepstream and TAO inference.py script is different. The TAO inference works very well for the cropped images from the primary engine (object detection). The images are almost all classified correctly.
However, it does not work well on deepstream itself when the model is deployed as a secondary engine. Many misclassifications and sometimes unable to classify also.
How do I configure the spec file on both sides so that both can produce the same/similar inference results? I have also tried following the config file in deepstream-test2 and tried playing around with almost all the parameters in the docs. The classifier secondary engine is still not outputting the correct result.
I have attached the spec file for training the efficientnet image classification model and the spec file to run the classifier as Secondary Inference Engine in Deepstream. Please help me take a look and see if there is any incompatibility between them.
Please refer to the hints in Classification inference huge performance degradation - #11 by Morganh
The deepstream inference works well with classification model.
