Cortex-R5 SPE partition flash
I would need to flash SPE partition (Xavier NX), so according to what explained in SPE deloper user guide I tried this:
sudo ./flash.sh -k spe-fw <T186 or T194 SoC based Jetson platforms> mmcblk0p1`
The procedure properly completes, but then the system goes to a continuous-reboot state. This is the error message we get from system TTY at every boot:
[0000.150] I> Boot-device: QSPI
[0000.153] I> Boot-device: QSPI
[0000.156] I> Qspi flash params source = mb1bct
[0000.160] I> Qspi using bpmp-dma
[0000.163] I> Qspi clock source : pllc_out0
[0000.167] I> Qspi reinitialized
[0000.170] I> Qspi flash params source = mb1bct
[0000.175] I> ECC region[0]: Start:0x0, End:0x0
[0000.179] I> ECC region[1]: Start:0x0, End:0x0
[0000.183] I> ECC region[2]: Start:0x0, End:0x0
[0000.188] I> ECC region[3]: Start:0x0, End:0x0
[0000.192] I> ECC region[4]: Start:0x0, End:0x0
[0000.196] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.202] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.206] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.210] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.215] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.220] E> FAILED: Thermal config
[0000.228] E> FAILED: MEMIO rail config
[0000.238] I> Boot-device: QSPI
[0000.241] I> Qspi flash params source = mb1bct
[0000.250] I> Qspi flash params source = mb1bct
[0000.261] I> Qspi flash params source = mb1bct
[0000.328] I> Qspi flash params source = mb1bct
[0000.337] I> Qspi flash params source = mb1bct
[0000.365] I> Qspi flash params source = mb1bct
[0000.370] E> LOADER: Failed to verify Stage2Signature SHA2.
[0000.375] E> LOADER: Failed to verify oem header.
[0000.380] C> LOADER: Could not read spe-fw.
[0000.384] E> failed to read spe fw from storage
[0000.388] E> AON SPE init failed
[0000.391] E> Task 78 failed (err: 0x251d0718)
[0000.395] E> Top caller module: AON, error module: LOADER, reason: 0x18, aux_info: 0x07
[0000.402] I> MB1(1.5.1.6-t194-41334769-1740dd39) BIT boot status dump :
0000000000011111111110111111111111111111111100111111101110011111111011011111111000000000000000000000000000000000000000000000000011111011000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
[0000.025] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.033] I> MB1 (prd-version: 1.5.1.6-t194-41334769-1740dd39)
[0000.039] I> Boot-mode: Coldboot
[0000.042] I> Chip revision : A02P
[0000.045] I> Bootrom patch version : 15 (correctly patched)
[0000.050] I> ATE fuse revision : 0x200
If I flash the full system (no “-k” option) then everything works fine
Thanks in advance
Andrea
Hello, Andrea:
Can you share the full flash command log with
sudo ./flash.sh -k spe-fw mmcblk0p1
The error log shows:
It means something wrong with spe-fw.
But if you follow the instructions in Jetson Sensor Processing Engine (SPE) Developer Guide: Compiling and Flashing (nvidia.com)
that should not happen.
BTW: Please make sure that the BSP version matches SPE firmware version. Though that may not be the key, we do suggest all components are with same version.
br
Chenjian
Hello Jachen,
thanks for your answer. I confirm that I followed all the steps in developer guide. I have just noticed that I copied the same binary both to spe_t194.bin and spe.bin, but I guess this could hardly be the reason behind my problem. As said, no problem if I flash the same firmware together with the rest of file system, by omitting “-k” option.
Here “flash -k” command log:
flash_host.txt (46.0 KB)
And here the relative output from Xavier’s system TTY, including multiple reboots after flashing:
flash_tty.txt (34.1 KB)
Andrea
Hello, Andrea:
That’s a little weird.
Have you ever changed anything in BSP?
I’ve tried flash -k spe-fw before in Xavier NX and it can work well.
(Sorry that I cannot access Xavier NX now so I cannot cross-check the flash log)
In addition, the BSP package version same as configurations, like eMMC xml?
br
Chenjian
Hello Jachen, yes, we did change something in the BSP. We have finally managed to program SPE though nv_bootloader_payload_updater tool. Flash -k option flow still under investigation.
Thanks for the support
Andrea
