Could not find any implementation for node failure of TensorRT 8.5 when running on GPU Jetson Xavier NX
Description
When I try to convert SuperPoint model from onnx to tensorrt engine using trtexec I faced
[optimizer.cpp::computeCosts::3728] Error Code 10: Internal Error (Could not find any implementation for node {ForeignNode[/Flatten...(Unnamed Layer* 139) [Shuffle]]}
error. It works in tensorrt 8.6 but since our workspace is Jetson Xavier NX and the latest supported Jetpack version for Xavier NX has Tensorrt 8.5, upgrading Tensorrt is not an option for now.
I also tried to simplify onnx model and it didn’t help me too.
Environment
TensorRT Version: 8.5
NVIDIA GPU: Jetson Xavier NX
CUDA Version: 11.4
Operating System: Jetpack 5.1.4
Python Version (if applicable): 3.8
This is model’s code:
import torch
from torch import nn
class MaxPool(nn.Module):
    def __init__(self, nms_radius: int):
        super(MaxPool, self).__init__()
        self.block = nn.MaxPool2d(kernel_size=nms_radius * 2 + 1, stride=1, padding=nms_radius)
    def forward(self, x):
        x = x.unsqueeze(dim=1)
        return torch.squeeze(self.block(x), dim=1)
def simple_nms(scores, nms_radius: int):
    """ Fast Non-maximum suppression to remove nearby points """
    assert (nms_radius >= 0)
    # def max_pool(x):
    #     return torch.nn.functional.max_pool2d(
    #         x, kernel_size=nms_radius * 2 + 1, stride=1, padding=nms_radius)
    max_pool = MaxPool(nms_radius)
    zeros = torch.zeros_like(scores)
    max_mask = scores == max_pool(scores)
    for _ in range(2):
        supp_mask = max_pool(max_mask.float()) > 0
        supp_scores = torch.where(supp_mask, zeros, scores)
        new_max_mask = supp_scores == max_pool(supp_scores)
        max_mask = max_mask | (new_max_mask & (~supp_mask))
    return torch.where(max_mask, scores, zeros)
def remove_borders(keypoints, scores, border: int, height: int, width: int):
    """ Removes keypoints too close to the border """
    mask_h = (keypoints[:, 0] >= border) & (keypoints[:, 0] < (height - border))
    mask_w = (keypoints[:, 1] >= border) & (keypoints[:, 1] < (width - border))
    mask = mask_h & mask_w
    return keypoints[mask], scores[mask]
def top_k_keypoints(keypoints, scores, k: int):
    if k >= len(keypoints):
        return keypoints, scores
    scores, indices = torch.topk(scores, k, dim=0)
    return keypoints[indices], scores
def sample_descriptors(keypoints, descriptors, s: int = 8):
    """ Interpolate descriptors at keypoint locations """
    b, c, h, w = descriptors.shape
    keypoints = keypoints - s / 2 + 0.5
    keypoints /= torch.tensor([(w * s - s / 2 - 0.5), (h * s - s / 2 - 0.5)],
                              ).to(keypoints)[None]
    keypoints = keypoints * 2 - 1  # normalize to (-1, 1)
    args = {'align_corners': True} if int(torch.__version__[2]) > 2 else {}
    descriptors = torch.nn.functional.grid_sample(
        descriptors, keypoints.view(b, 1, -1, 2), mode='bilinear', **args)
    descriptors = torch.nn.functional.normalize(
        descriptors.reshape(b, c, -1), p=2, dim=1)
    descriptors = descriptors.permute(0, 2, 1)
    return descriptors
default_config = {
    'descriptor_dim': 256,
    'nms_radius': 4,
    'keypoint_threshold': 0.0005,
    'max_keypoints': 1024,
    'remove_borders': 4,
class SuperPoint(nn.Module):
    """SuperPoint Convolutional Detector and Descriptor
    SuperPoint: Self-Supervised Interest Point Detection and
    Description. Daniel DeTone, Tomasz Malisiewicz, and Andrew
    Rabinovich. In CVPRW, 2019. https://arxiv.org/abs/1712.07629
    # default_config = {
    #     'descriptor_dim': 256,
    #     'nms_radius': 4,
    #     'keypoint_threshold': 0.005,
    #     'max_keypoints': -1,
    #     'remove_borders': 4,
    def __init__(self):
        super().__init__()
        # self.config = {**self.default_config, **config}
        self.relu = nn.ReLU(inplace=True)
        self.pool = nn.MaxPool2d(kernel_size=2, stride=2)
        c1, c2, c3, c4, c5 = 64, 64, 128, 128, 256
        self.conv1a = nn.Conv2d(1, c1, kernel_size=3, stride=1, padding=1)
        self.conv1b = nn.Conv2d(c1, c1, kernel_size=3, stride=1, padding=1)
        self.conv2a = nn.Conv2d(c1, c2, kernel_size=3, stride=1, padding=1)
        self.conv2b = nn.Conv2d(c2, c2, kernel_size=3, stride=1, padding=1)
        self.conv3a = nn.Conv2d(c2, c3, kernel_size=3, stride=1, padding=1)
        self.conv3b = nn.Conv2d(c3, c3, kernel_size=3, stride=1, padding=1)
        self.conv4a = nn.Conv2d(c3, c4, kernel_size=3, stride=1, padding=1)
        self.conv4b = nn.Conv2d(c4, c4, kernel_size=3, stride=1, padding=1)
        self.convPa = nn.Conv2d(c4, c5, kernel_size=3, stride=1, padding=1)
        self.convPb = nn.Conv2d(c5, 65, kernel_size=1, stride=1, padding=0)
        self.convDa = nn.Conv2d(c4, c5, kernel_size=3, stride=1, padding=1)
        self.convDb = nn.Conv2d(
            c5, default_config['descriptor_dim'],
        # path = Path(__file__).parent / 'weights/superpoint_v1.pth'
        # self.load_state_dict(torch.load(str(path)))
        # mk = default_config['max_keypoints']
        # if mk == 0 or mk < -1:
        #     raise ValueError('\"max_keypoints\" must be positive or \"-1\"')
    def forward(self, data):
        """ Compute keypoints, scores, descriptors for image """
        # Shared Encoder
        x = self.relu(self.conv1a(data))
        x = self.relu(self.conv1b(x))
        x = self.pool(x)
        x = self.relu(self.conv2a(x))
        x = self.relu(self.conv2b(x))
        x = self.pool(x)
        x = self.relu(self.conv3a(x))
        x = self.relu(self.conv3b(x))
        x = self.pool(x)
        x = self.relu(self.conv4a(x))
        x = self.relu(self.conv4b(x))
        # Compute the dense keypoint scores
        cPa = self.relu(self.convPa(x))
        scores = self.convPb(cPa)
        scores = torch.nn.functional.softmax(scores, 1)[:, :-1]
        b, _, h, w = scores.shape
        scores = scores.permute(0, 2, 3, 1).reshape(b, h, w, 8, 8)
        scores = scores.permute(0, 1, 3, 2, 4).reshape(b, h * 8, w * 8)
        scores = simple_nms(scores, default_config['nms_radius'])
        # Extract keypoints
        keypoints = [
            torch.nonzero(s > default_config['keypoint_threshold'])
            for s in scores]
        scores = [s[tuple(k.t())] for s, k in zip(scores, keypoints)]
        # Discard keypoints near the image borders
        keypoints, scores = list(zip(*[
            remove_borders(k, s, default_config['remove_borders'], h * 8, w * 8)
            for k, s in zip(keypoints, scores)]))
        # Keep the k keypoints with highest score
        if default_config['max_keypoints'] >= 0:
                top_k_keypoints(k, s, default_config['max_keypoints'])
        # Convert (h, w) to (x, y)
        keypoints = [torch.flip(k, [1]).float() for k in keypoints]
        # Compute the dense descriptors
        cDa = self.relu(self.convDa(x))
        descriptors = self.convDb(cDa)
        descriptors = torch.nn.functional.normalize(descriptors, p=2, dim=1)
        # Extract descriptors
        descriptors = [sample_descriptors(k[None], d[None], 8)[0]
                       for k, d in zip(keypoints, descriptors)]
        return {
            'keypoints': keypoints,
            'scores': scores,
            'descriptors': descriptors,
I believe what’s causing this error is this line :
Hi @f.requiem11 ,
I would recommend reaching out to JEtson Team for feasibility check.
