The driver version in the compute nodes are 304.54, which is suitable for CUDA 5.0. Note that I don’t have permission to upgrade the driver version.
When I compile a CUDA Fortran code using PGI 12.10, it works and runs right. When I compile the same code using PGI 15.7, compilation is passed but it runs corrupted with info:
0: ALLOCATE: 4096 bytes requested; status = 35(CUDA driver version is insufficient for CUDA runtime version)
I know the reason: the executable use shared libs which version is CUDA 6.5 by default.
I notice that there is no version less than 5.5 in my directory ~/software/pgi-2015-157/linux86-64/2015/cuda. So does driver version 304.54 support PGI 15.7 compiler? How can I use PGI 15.7 under driver version 304.54?
I try adding -rc=rcfile to explicitly specify CUDA 5.0, but the compilation is aborted with infor:
Could not open libnvvm.
PGF90-F-0155-Compiler failed to translate accelerator region (see -Minfo messages):
Device compiler exited with error status code (vectorAdd.cuf: 1)
The test code file vectorAdd.cuf:
module add_mod
use cudafor
integer, parameter :: N = 1024
end module add_mod
program vectorAdd
use add_mod
implicit none
integer :: i
real :: mysum
real, allocatable :: A(:), B(:), C(:)
real, allocatable, device :: d_A(:), d_B(:), d_C(:)
allocate(A(N), B(N), C(N))
allocate(d_A(N), d_B(N), d_C(N))
A = 1.0
B = 2.0
d_A = A(1:N)
d_B = B(1:N)
!$cuf kernel do(1) <<<*,*>>>
do i = 1, N
d_C(i) = d_A(i) + d_B(i)
enddo
C = d_C(1:N)
do i = 1, N
mysum = A(i) + B(i);
if (abs(C(i) - mysum) > 1e-5)then
exit
endif
enddo
if (i==N+1)then
write(*,*) "PASSED"
else
write(*,*) "FAILED"
endif
if (all(C==A+B))then
write(*,*) "PASSED"
endif
deallocate( d_A, d_B, d_C )
deallocate( A, B, C )
end program vectorAdd
The compilation command in build.sh:
#!/bin/bash
OPT='-Mcuda -Minfo -rc=rcFile'
pgf90 $OPT vectorAdd.cuf
The rcFile:
set CUDAROOT=/vol-th/software/cuda/cuda-5.0;
set CUDAVERSION=5.0;
Thanks in advance!
