Good morning. I am currently experiencing a crash when trying to run Nsight Graphics 2019.1 on my application.
The applications start, run a few frames then NSight crashes.
I managed to get a memory dmp. By the looks of it, the crash is deep in the NVidia dll and possible related to an allocator. (Maybe command allocator)?
For comparison, I am able to run the application successfully no crashes on four systems spanning a various combination of the all three major IHV. Pix and Radeon profiler work with no issues on all applicable platforms.
The attached dmp file is created on a system with 2700X + 2080ti. Raytracing DXR is not involved. Device and command list are V3.
Dump: https://1drv.ms/u/s!Ai0n7iKmKMz0gbEQoyqyYNKSPusDRQ
Any idea?
On a side note, I am not able to attach to a process rather than let NSight kick the application start. If I go on the “attach” tab no processes are displayed on localhost.
Here part of the analysis of the dmp:
PRIMARY_PROBLEM_CLASS: NULL_POINTER_READ
BUGCHECK_STR: APPLICATION_FAULT_NULL_POINTER_READ
LAST_CONTROL_TRANSFER: from 00007ffda592dda2 to 00007ffd7f2f6412
STACK_TEXT:
00000016`f11ef048 00007ffd`a592dda2 : 00000000`00000008 00007ffd`844b4498 00000206`7c890fa0 00000206`7c86dd50 : nvwgf2umx+0x3d6412
00000016`f11ef050 00000000`00000008 : 00007ffd`844b4498 00000206`7c890fa0 00000206`7c86dd50 00000206`7c890fa0 : nvapi64+0x25dda2
00000016`f11ef058 00007ffd`844b4498 : 00000206`7c890fa0 00000206`7c86dd50 00000206`7c890fa0 00007ffd`843f9272 : 0x8
00000016`f11ef060 00000206`7c890fa0 : 00000206`7c86dd50 00000206`7c890fa0 00007ffd`843f9272 00000000`00000000 : D3D12!`CCommandAllocator::_GetEntries'::`2'::_entries+0x28
00000016`f11ef068 00000206`7c86dd50 : 00000206`7c890fa0 00007ffd`843f9272 00000000`00000000 00000000`00000000 : 0x206`7c890fa0
00000016`f11ef070 00000206`7c890fa0 : 00007ffd`843f9272 00000000`00000000 00000000`00000000 00000000`00000000 : 0x206`7c86dd50
00000016`f11ef078 00007ffd`843f9272 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x206`7c890fa0
00000016`f11ef080 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : D3D12!CPrivateData::Set+0x6e
STACK_COMMAND: ~0s; .ecxr ; kb
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: nvwgf2umx+3d6412
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nvwgf2umx
IMAGE_NAME: nvwgf2umx.dll
DEBUG_FLR_IMAGE_TIMESTAMP: 5c5b3624
FAILURE_BUCKET_ID: NULL_POINTER_READ_c0000005_nvwgf2umx.dll!Unknown
BUCKET_ID: X64_APPLICATION_FAULT_NULL_POINTER_READ_nvwgf2umx+3d6412
WATSON_STAGEONE_URL: http://watson.microsoft.com/StageOne/Sandbox_exe/0_0_0_0/5c67e9a7/nvwgf2umx_dll/25_21_14_1891/5c5b3624/c0000005/003d6412.htm?Retriage=1
bf00aa7b-4a5b-4dbd-8288-d32956882e88.7z (12.1 KB)
