Hello everyone,
I’ve successfully set up JetPack SDK on my Jetson Orin Nano, flashed it with a Custom Kernel and set up OP-TEE along with Disk Encryption. OP-TEE is running fine, and I’ve already tested several Trusted Applications such as the hello world or hwkey agent sample from NVIDIA’s documentation..
Now I’m working on a Trusted Application that should interact with the TPM module on the Jetson.
From the Linux terminal on the Jetson, I can run commands like tpm2_pcrread, tpm2_pcrextend, and tpm2_selftest successfully — so the TPM and tpm2-tools are working as expected in normal world.
What I want to do now is:
- Access the TPM directly from within the Trusted Application, without relying on Linux-side tooling (because it is not working there)
- Ideally perform a PCR Extend operation via the TA
Thanks in advance!
